Camera Shutter Button not working
'“When taking a picture, I hold the shutter button down, and nothing happens.”
Hold power button down
Before opening up camera to see if something is broken, first...
Check if Shutter Button is in good condition
Remove battery to force a shut down
If the power button is loose, stuck, or otherwise unresponsive
See our replacement guide to show you how to replace it.
Camera lens not working/ error message
“My lens seems jammed, it does not open”
Miss alignment when the camera is being powered down, causing parts in the lens to jam
This can be fixed by gently trying to push the lens back into the proper place. Minimizing the motion it would do when it was properly working.
Jammed lens
This can also be fixed by gently trying the lens back in the body of the camera, make sure that you reset the camera after it is properly in its place.
Flash troubleshooting
“Flash is not coming out when taking pictures”
This could be a low internal battery
Replace the internal battery.
Settings are not properly formatted
Make sure that the camera flash is turned on; if flash does not continue to turn on restore your cameras factory settings by taking out the battery and memory card for at least fifteen seconds.
Camera will not accept batteries
“There seems to be a problem with the spring that accepts the batteries.”
Remove the Battery Cover
The battery door may need to be removed. Remove the battery cover and set it aside.
If the camera spring is loose, stuck, or otherwise unresponsive
See our replacement guide to show how to disassemble the camera and replace the spring
Camera got in contact with water
“I got my camera wet and now it won’t work.”
If camera is not working
Soak your phone in 99% Isopropyl alcohol for about two hours. Having that done, put camera in a bag of uncooked rice for a few hours. In this stage the rice will absorb all the moisture and hopefully restore the camera.
If camera battery intake is damaged due to contact with water
See our replacement guide to show how to disassemble the camera and replace all proper pieces back into place
0 commentaires
