Wiki réalisé avec l'aide d'étudiants
Une formidable équipe d’étudiants de notre programme éducatif a créé ce wiki.
Console Display goes Blank
When pressing the power button, the display does not give any details and seems to be powered off.
Battery is Dead
When battery is out, the screen goes completely blank. Then it's time to replace new battery.
All Displayed Data are Inaccurate
All the numbers includes dates, time, and temperature are displayed incorrectly.
Motherboard is Broken
Displayed data are inaccurate when the motherboard burns out. When the motherboard is broken, you would need to open the device and carefully replace a new motherboard which is located at the center of the device.
Screen is cracked
When the screen is cracked and the display does not show the temperature, you need to replace it with a new screen.
Caused by External Factors
The device was possibly not properly installed and dropped on the floor, cracking the screen. The screen simply needs to be replaced.
Buttons do not work
Nothing happens when buttons are pressed. This could be because the buttons have gotten old.
Poor Contact of Flat Cable Between the Motherboard and the Buttons
The flat Cable inside the device is not properly connecting to the motherboard, causing the buttons to not make the proper contact.
0 commentaires
