Wiki réalisé avec l'aide d'étudiants
Une formidable équipe d’étudiants de notre programme éducatif a créé ce wiki.
Computer Will Not Turn On
No matter what you do, you can't get your computer to turn on.
Faulty Power Adapter
If the charging light does not turn on when the computer is plugged in, the power adapter might be faulty. Try plugging the computer into a different outlet. If the light still does not come on, your power adapter might be faulty. Try using a different power adapter.
Old and Worn Out Battery
If the computer works when it is plugged in but turns off when unplugged, the battery is probably faulty. To solve this, try replacing the battery.
Computer Will Not Boot
The power light comes on, but the operating system will not boot.
Defective RAM
When turning on your computer it works fine. However, only when you decide to open up a program or website, does the computer performance start to noticeably be slower and may even crash. When this happens, there is not enough RAM or you have RAM that is too slow or old. To solve this, try replacing the RAM.
Keyboard Does Not Work
The keyboard is not responsive or keys are missing.
Keys Are Unresponsive
If the keys are unresponsive, the keyboard may be disconnected. If the keyboard is connected and still unresponsive, try [lien de tutoriel non valide].
Keys Are Missing
If keys are missing, you can try to purchase replacement keys and install them, but it might be easier to just [lien de tutoriel non valide].
Screen Does Not Work
The screen is physically damaged or does not function as expected.
Screen Is Cracked or Faulty
If the screen is physically broken or cracked or if the screen does not display anything or if the screen display is distorted, try replacing the display.
Disabled Display
If the computer is turned on but the screen does not display, then the display may be disabled. If the display is disabled, press the 'Fn' button on the lower left side of the keyboard and then press the 'F6' button on the top of the keyboard. This should enable the display.
Computer Will Not Play Audio
The computer will not play sounds, but the volume is not muted.
Faulty Audio Jack
If the audio jack is broken or is not functional, try replacing the audio jack.
Faulty Audio Driver
If the audio is distorted or does not play, then the audio driver may be faulty. Try updating the current audio driver or installing a new audio driver.
0 commentaires
