Wiki réalisé avec l'aide d'étudiants
Une formidable équipe d’étudiants de notre programme éducatif a créé ce wiki.
Device Does Not Charge
You have trouble listening to sounds on your computer.
Charging Cable Is Damaged
It is possible that the charging cable has failed. The wires inside the charging cable might not connected. If available, try using another compatible charging cable. If that does not solve the problem then proceed to the next possibility.
Dirty Contacts
Check the charging port for any debris that could have accumulated inside of it potentially insulating the charging cable from the phone not allowing electricity to flow. If this is the case use compressed air to blow out any debris and retry charging the device. If neither of these solutions addressed the problem continue to the final step.
Broken Charging Port
Any liquid can damage the device preventing it from working by possibly corroding terminals or shorting them. Try cleaning the port with a lint free tissue to remove or loosen materials that should not be in the charging port, then blow it out with compressed air. Try charging the device once more. If no solutions have worked then the battery has likely failed and the battery should be replaced.
Audio Is Distorted
Tablet’s sound is distorted whether using headphone or speaker.
Device Is Muted
Make sure the tablets volume is on. Adjust the volume in sound settings or turn it up and down using the button on the right hand side of the device.
Out Of Date Software
If the software in the tablet is not the most current version, this may cause some problems with the audio. Update to the newest version and restart the tablet after that.
Dust In Audio Port
If the audio port is dirty, the headphone jack might not be connected properly. Test the headphones with another device to make sure the headphones are not damaged. If they work with another device and the jack is clean, it is possible the audio jack is damaged and it should be replaced.
Broken Speaker
Broken speaker is one of the most common hardware issue resulting in distorted sound. If the mentioned solutions still cannot solve the problem then the speaker is likely defective. This may be solved by replacing the wires that are connected with the speaker or the speaker itself.
Camera Is Not Working Properly
Photo quality is poor.
Blindfolded Camera Lens
Please check to make sure that the camera lens is not covered by anything such as the case protector.
Dust On Camera Lens
If pictures are blurry the camera lens might have dust on it or fingerprint smudges on it. Please use cleaning tool such as lens brush to wipe the dust out.
If the software in the tablet is not the most current version, this may cause some problems with the camera not working. Update to the newest version and restart the tablet after that.
Broken Camera
If these solutions did not work, the camera may need to be replaced.
Screen is not Responding
Display screen is unresponsive or frozen.
Dirty Screen
The screen can collect and build up dust very easily. You can try to clean up your screen by using cleaning tissues in order to improve the touch sensitivity.
Broken Screen
The issue might be related to broken parts connected to the display. Try to replace the digitizer connected to the display and LCD.
Full Storage
Slow response and frozen screen may be caused by full memory storage. Be sure to remove any unnecessary data (photos, videos, apps) in order to achieve smooth performance.
Operating System Glitch
A lot of operating system issues can lead to unresponsive or frozen screen. Some of the possible solutions are checking for Android updates, resetting the device to factory settings.
Tablet Shuts Off And Will Not Turn On
The tablet cannot power on at all
Software Glitch
Software glitches can cause the device to not work. Please try to do a factory reset or reinstall the operating system.
Faulty Display Screen
If assure that the device’s power is on, chances are the display screen is defective. At this point, screen replacement is necessary.
Bad/Dead battery
Before tearing into the device, try to charge your battery using different charger to make sure that your charger is not faulty. If this is still not working, your battery is probably dead and a battery replacement is necessary.
Motherboard Is Damaged
Spilled water or any other liquid into the tablet might affect to the motherboard inside the tablet and cause the tablet to shut off. If this is a case, motherboard replacement may be necessary.
Factory Reset
To Factory Reset your device please follow these instructions. Make sure the device is turned off. Press and hold the volume up and power buttons for 10 seconds. When the Lenovo Logo appears on the screen release the buttons. A menu should appear on screen. Use the volume controls to select the factory reset and the power button to accept it. Tap the screen select yes to clear all data on the device. Finally use the power button to select the system reboot option.
Un commentaire
Menu is not appearing, tried multiple times. Screen freezes with no response. What should I do?
Akash Uppal - Réponse
