The trigger is pulled and nothing happens
Silent but deadly does not apply here. Cue the crickets.
Magazine was not inserted correctly
Make sure that the magazine was inserted all the way.
Slide Placement
The slide should be pulled all the back and then returned to its original position.
Trigger is pulled but nothing comes out
Is my aim that bad or did nothing come out?
Missing Darts/Magazine
Make sure a magazine has been inserted and that it has darts in it.
Jammed Dart
Open up the access gate on the top of the gun and manually remove the darts. If the dart is too far in to reach to reach by hand, insert a stiff wire through the access gate and down the barrel to push it out.
Wrong Darts
This gun does not handle the suction darts well; it works best with elite darts. If the suction dart gets jammed, follow the instructions stated in the previous section to remove it.
Stuck Magazine
How did I get it in here in the first place?
Magazine Release
Pull the small orange button in front of the trigger guard. This button is the magazine release and should drop the magazine.
Slide Placement
The slide must be pulled all the way back to allow the magazine release to be pulled.
Slide won't move back
I like to move it, move it. This slide should take a lesson from those lemurs in Madagascar.
Already Loaded
The gun has already been loaded. It's time to fire!
Jammed Dart
There's a dart stuck in the barrel of the gun. Insert a stiff wire through the access gate and down the barrel to push the dart free.
Broken Hammer Rod
The silver hammer rod is bent or broken. Follow the directions in this repair guide to remove the part.
Trigger is jammed
Jam belongs in sandwiches, not your nerf gun.
Slide Placement
Move the slide to the forward position in order to fire.
Broken Spring
The spring that allows for the movement of the trigger could be broken. Follow the directions in this repair guide to remove the part.
6 commentaires
i need help asap please whenever i prime my gun it goes back by its self and de-primes and i dont know what to do P.S. it has a orangemodworks mod kit installed
ShoeNugget - Réponse
Slide will not go all the way forward so cannot fire any ideas how to fix it
Rob - Réponse
i dont know what is wrong with it i shoot and the bullet comes out but it falls to the ground
jess - Réponse
It doesn't handle used darts very well. Also, don't aim downwards as the bullet will slide out.
Hallvard Hvidsten -
Replacement spring is longer than the original and doesn't seem to work in the blaster. It will prime but not fire?
Tracey Buckle - Réponse
