Wiki réalisé avec l'aide d'étudiants
Une formidable équipe d’étudiants de notre programme éducatif a créé ce wiki.
Samsung Galaxy Tab A 7.0 Troubleshooting Page
This troubleshooting page will help you diagnose problems with the Samsung Galaxy Tab A 7.0.
Device Will Not Charge
The device will not charge when connected to power.
Faulty Charger
Test faulty device with other chargers. If the device charges after using another power adapter then the original charger was faulty.
Faulty Charge Port
Test faulty device with other chargers. If faulty device does not charge after testing other chargers and/or the charging port looked corroded or damaged charge port that needed to be replaced. A video tutorial for the same repair on an earlier model of this device can be found at this link: https://www.youtube.com/watch?v=5OGYMVA0...
Volume Buttons Will Not Work
The volume buttons will not respond when pressed.
Software Issue
Restart the device to reset the software. If the volume buttons work after restarting the device, a software glitch is likely the issue.
Buttons Do not Press
Inspect the device for dirt and dust impeding volume button to be pressed. Also check for any sticky substance. If debris is found, clean with an air duster or rubbing alcohol with a q-tip. If the problem persists, the volume buttons might be malfunctioning and might need to be replaced. A link to a repair guide is given here: Remplacement du bouton de volume du Samsung Galaxy Tab A 7.0"
Broken Screen
Faulty display on device.
Shattered Screen on Device
If the screen is shattered, not much can be done to repair it. The screen must be replaced. A link to a video tutorial on replacing the screen is given here: https://www.youtube.com/watch?v=v5PgwtG-...
Front Facing Camera Does Not Work
The camera does not work when activated.
Camera Does not Respond
If the display does not show while using the camera function, a software issue might be the problem. One possible solution to this issue would be to restart the device. If the camera function works properly following the restart then a software glitch was likely the problem. If the problem persists, it is possible the camera became disconnected from the motherboard. Following the replacement guide in the section below, you will see where the camera is connected and how to connect and disconnect it from the device.
Cracked Camera Lens
If the camera lens is shattered, not much can be done to repair the lens. The camera will need to be replaced. A replacement guide can be found at the link below: Remplacement de la caméra frontale du Samsung Galaxy Tab A 7.0"
Audio is Distorted
Trouble with sound through headphones.
Headphone Jack Connection Issues
Examine the headphone jack looking for any debris clogging the port. This could inhibit or disrupt connection to audio output devices If so, use an air duster to remove possible clogging. If the headphone jack is clear of debris and poor connection persists, the jack itself may be faulty. A replacement guide can be found at this link: Remplacement de la prie casque du Samsung Galaxy Tab A 7.0"
Headphones are Faulty
Closely examine the headphone cord looking for any exposed metal wire. If the wire appears intact and no metal is showing then try a different pair of head phones. If the audio issue is not apparent with the new headphone then it is likely that the original headphones are faulty.
20 commentaires
My Galaxy Tab A 7" suddenly shut off and will not turn on. It was fully charged when it went off. Suggestions? Could it be a faulty battery? Other ideas?
LJPurkey - Réponse
I am aslo facing same problem with my Samsung Galaxy Tab A7.0
Rajnish Singh - Réponse
My Galaxy Tab A won't go to my front page, it is fully charged and it will turn on. It shows that it will not connect to my wi-fi. It shows turn of or restart but it won't work. Need to use side button to shut down. Any suggestions.
egflores1954 - Réponse
The keyboard will not appear to unlock tablet
scot lantz - Réponse
Speaker is off with skype
Barbara Meiselbach - Réponse
