Batterie
7 Réponses Indice de 7 |
Paperwhite refuses to turn on, LED blinks 4 times. |
2 Réponses Indice de 0 |
kindle paperwhite 2nd generation screen frozen at battery empty |
3 Réponses Indice de 1 |
Why is my screen unresponsive to touch? |
1 Réponse Indice de 0 |
Why is my battery draining quickly? |
Pièces
Outils
Voici quelques outils couramment utilisés pour travailler sur cet appareil. Vous ne devriez pas avoir besoin de tous les outils pour chaque procédure.
Modèles
3G & Wi-Fi, Wi-Fi
Background
The Kindle Paperwhite is the 2nd Generation of the device, released in late 2013. If the Kindle has the ability to power on, you can verify that you have a 2nd Generation Kindle Paperwhite by clicking on Settings and then Device Info. Once this is done, a 16-digit code will be displayed, if this code begins with “B0D4” or “90D4” your device is a 2nd Generation Kindle Paperwhite. The Kindle Paperwhite differs from other Kindles by not having the 5-way controller present in other Kindle Models, and by having a built-in light that can be adjusted manually.
The First Generation Kindle Paperwhite model was introduced in October 1, 2012, by Amazon with the release being centered around the addition of a manually adjusted light level. This model was well received, so a year later (September 30, 2013) the Second Generation Kindle Paperwhite was released. The Second Generation Kindle PaperWhite was released with a 6’’ Screen, a 1GHz Processor, 4GB of Storage, and the ability to connect to wifi. This model was also well received.
Identification
The backside of the device contains a label that lists the model number as DP75SDI. It is available in black.
Device Specifications
Screen size: 6 in
Pixel Density (ppi): 212
Processor Speed: 1 GHz
Ram: 2GB
Wireless Connectivity: 802.11b/g/n
Flash Storage: 2 GB integrated / 4 GB integrated
Supported Text Formats: TXT, PDF, HTML, DOC, DOCX, PRC, AZW
Supported Still Image Formats: BMP, GIF, JPEG, PNG
Input: Micro-USB
Battery Life: 28 hour
Additional Documentation
Kindle Paperwhite 2nd Edition Teardown
Kindle Paperwhite 2nd Edition on Wikipedia
