Aller au contenu principal
Repair guides and troubleshooting for the Acer Aspire V5, a series of laptops on the Windows OS by Acer.
132 questions Voir tout
Acer Aspire v5-571P - Replace the network card?
I purchased an Acer Aspire V5-571P-6648 for my wife for Christmas. We love Windows 8 (no comments here please) and the touch screen. However, we are frequently losing internet connectivity. Only a restart seems to resolve the issue. I have multiple devices on WiFi and do not see connectivity issues on the other devices. Searching the web reveals that there are problems with the Atheros network card in the unit. I reached out Acer and they, unfortunately of no help here. I'm an IT guy so I have no problem replacing the unit if it is replaceable.
Does anyone know if the NIC is replaceable with another one?
Répondu ! Afficher la réponse J'ai le même problème
Indice 2
Ajouter un commentaire
5 Réponses
Solution retenue
Not sure if this helps you.
The original Apple 802.11a/b AirPort card (PC card) and the current 802.11n AirPort card (PCI-E 450M) are both Atheros cards. They have had a good track record and the current version of BootCamp supports Windows 8 and has been stable over WiFi.
I wonder if the system is up to running Windows 8, as this system only has an Intel i3 chip. Could the dropouts be more a hardware/OS issue (or driver) Vs a bad WiFi card?
Try running Windows PerfMon service to see if the interface is being Interrupt starved. Does having less things running concurrently (loaded) do better than when you have a lot running as the same time?
I would go back to Acer as others have likewise made note of having problems looking through google.
Indice 1
1 commentaire:
This caught my eye today and I was thinking you maybe facing a similar issue Samsung Series 9 Ultrabook. I would check out Atheros' web site for newer drivers.
par
Réponse la plus utile
Before you do anything, try this:
Go to device manager (Windows key + X is the quickest way there)
Under network adapters, find your wifi device and get properties (right click it)
Go to the "Power Management" tab and uncheck "Allow the computer to turn off this device to save power".
What kept happening to me was windows would turn off wifi to save power when the laptop was idle, but wouldn't turn it back on. This workaround solved the issue for me.
Indice 3
1 commentaire:
sterownik karty wifi
par
I replaced the WLAN card with the Intel 7260 HMW to get 802.11AC without any issues. Just open it from the bottom instead of the top like the service manual shows and it's a <15 minute installation.
I don't know what all the fuss is about with this series laptop, it is thin but really not that hard to open up. Also replaced with a Samsung 840 Pro SSD which was a breeze as well. There is practically no way to screw it up since the bottom easily pops off without any ribbons or cables to unhook.
Indice 3
all NIC cards are replaceable. you just have to obtain the right one. if you go to your device manager and look whether it is Atheros or reltech for example. once you get that you can obtain it from their website or a part supplier.
Indice 0
1 commentaire:
Sorry to say not always true. Many newer systems have the Ethernet services embedded in the logic board and now we're starting to see WiFi also embedded into the logic board.
par
I have the same problem with my Acer v3-571g. In my case the network card deactivates itself even when im connected via ethernet cable (at first i thought maybe its just a wifi problem). And it's so frustrating because I have to restart in order to make it work again...
I tried a lot of solutions, seems nothing is working.
Did you manage to fix your problem?
Indice 0
Ajouter une réponse
Eric Wahl sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 9
30 derniers jours : 21
Total : 14,435
