General advice on ALL copier/’printer jams…a WHOLE piece of paper in should equal a WHOLE piece of paper out. No printing device has a capability to “absorb” a stray scrap of paper. Typically, a small scrap of paper will come to rest at or near a sensor or a sensor arm (also called a flag). A “paper jam”, in most home printers, does not necessarily mean that verbatim. It’s also used as a “kitchen drawer” descriptor for anything short of software, print head or other circuity issues. Always do the following at jam-time: 1) If your unit gives a sequential removal/clearing tutorial, follow it. 2)….grab any piece of paper to be removed using BOTH HANDS,-pull EVENLY with both hands, steady pressure. If the paper begins to tear STOP, try to re-grip closer to the nip (where the two rollers meet) of the rollers, and try again. Yes, I know this seems like it takes far longer than simply yanking out the offending piece, But you won’t be left without a printer because of a scrap floating around inside.,.AND MOST IMPORTANTLY,,,Always attempt to remove paper in the same direction it was travelling. It will not always be possibly to do this. At those times, try to observe anything the paper is touching as you remove it-it is relatively easy to generate sufficient force to knock a sensor flag out of position.
ALL COPIERS AND PRINTERS——-sense jams this way…..X amount of time to be picked up from the tray, and arrive at it’s first check point, and from there, to it’s next check point. That process is repeated the entire distance through the paper path. If it fails to get there on time, VIOLA!….Le Jam.
CLEAN YOUR ROLLERS…Yes, you can do it!. Use alcohol (insert joke here)and a scrub sponge…not for some types of “foam” rollers nowadays. If you put alcohol on rubber rollers, they will get clean , and will feed the paper properly. Before you clean the rollers, feel them. If they are slippery-smooth, they are too dirty, or too old. If too old, they will become sticky when cleaned, and wont become “un-sticky” for a while, if at all.
Try to never run pre-printed paper thru again. Yes, many companies say it is OK…….IT IS DEFINITELTY NOT !!!! Every piece fed thru will leave some residue on the rollers, and pre-printed ink is worse than toner. Over a brief period, the residue builds up….then the jams start because the paper is slipping, and not quite getting to its next check point. Once the roller become impregnated, they are history. Cleaning will only be a very temporary fix.
I was a Canon Tech for many years,… hope this helps you all.
Canon has an excellent end-user advice forum….when in doubt…
A voté
Annuler
Indice
14
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter commentaire à cette contribution » pour le déplacer.
20 commentaires
keeps saying paper jam but no paper anywhere inside or out.
and always false printing paper coming out
par CHANDRA KANTA GHOSH
I wish I knew. My Canon MG2920 is doing the same exact thing, and none of the suggestions helped. I do appreciate everyone's help on this board :-)
par Rhonda Lee
I have the same problem. There was a paper jam
but I cleared it. No joy. Have dis-assemled the unit
twice and THERE IS NO JAM. Software problem?
Can the software be replaced/updated?
par Gar Kol
Having the same problem. I did have a paper jam. I got all the paper out of the jam from all three angles. When it takes the paper, it crinkles it up and says no paper. My daughter has a project do thats already late and I'm not sure what to do ..Canon Pixma(mg6821)
par Chenoa Steiner
paper jam. but no paper canon IR2520
par nahom kitamo
Voir 15 commentaires en plus
