Aller au contenu principal
Guide de réparation et support pour les ordinateurs de bureau produits par Asus incluant les tours et les ordinateurs tout-en-un.
144 questions Voir tout
no signal from computer to moniter
Their is no signal from my Asus essentio to the monitor . The monitor is working fine as I have cctv cameras attach to monitor and it is displaying them fine, I have also checked cables which are all fine. This has lead me to believe that this could be the graphics card . I have taken a look inside the computer and I can t see the normal set up with a removable graphics card attached to the vga port so I am now wondering if the whole motherboard needs replacing. Thanks
Répondu ! Afficher la réponse J'ai le même problème
Indice 3
Ajouter un commentaire
3 Réponses
Solution retenue
haguehags ,
Hope This answer will hep you to get idea to fix you PC
Indice 1
1 commentaire:
this isnt hel[ full
par
Greetings,
Check the monitor for which type of input signal it is currently set for.
- there should be a choice within the set-up options for Dvi, HDMI, Display port or whichever cable type the Pc is connected to the monitor with.
- insure that the cctv cameras are not set as the default source.
Hope this helps in attaining a signal.
Indice 0
asus pentium3 power ok ram clean ok showing signal ditected
Indice 0
Ajouter une réponse
haguehags sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 12
30 derniers jours : 52
Total : 4,288
