Aller au contenu principal
Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
576 questions Voir tout
Replacing HD portion of Fusion Drive with SSD
Hi
I want to replace the HD in my iMac 27" 5k systems Fusion Drive with a SSD.
Can I run this iMac with a 24 G flash drive on motherboard (apparently this flash drive is not yet upgradeable?) and this new SSD (in the place of the HD)
Essentially I would have 2 SSD drives (one big and one small)
How do I set it up after the install?
Répondu ! Afficher la réponse J'ai le même problème
Indice 5
3 commentaires
Can you give us the make and model of the SSD you want to put in to replace the current HD. You also talk about upgrading the current SSD as well here which is a 24 GB SSD? Are you asking if you can put in a 2 TB PCIe blade drive in in place of what you have now? Also what is the exact config your iMac has now HD & SSD.
par
Hi
I am not sure what make HDD Apple use
This is a fairly new 27 inch Imac with a 1T fusion drive . It is not a hybrid fusion drive-it is as it came from apple.
My conern is if i just replace the HDD portion of the fusion drive with a SSD and leave the 24G flash portion as is in the motherboard wil the imac just runnir do i need to change the setup or settings of the hardware.
thx for the help
par
OK, lets review then what you have: a Stock 1 TB HD and a 24 GB SSD setup as a Fusion Drive. FYI: Apple slims 1 TB Fusion Drive down to a measly 24 GB of flash storage
par
Ajouter un commentaire
8 Réponses
Solution retenue
Frankly, I would not upgrade this system as it has a faster Thunderbolt external port than what the internal HD SATA III port offers.
Lets look at the numbers:
  • SATA III - 6.0 Gb/s
  • Thunderbolt 1 - 10 Gb/s
  • Thunderbolt 2 - 20 Gb/s
So depending on which exact model you have you might have a TB2 interface which is much faster!
Now lets look at the PCIe interface the blade SSD is currently using
  • PCIe 2 Lane (AHCI) - 10 Gb/s
  • PCIe 4 Lane (NVMe) - 32 Gb/s
So if you wanted a faster system using an internal drive I would invest the effort replacing the blade SSD with a much bigger SSD unit. Apple offers a 1 TB bade SSD but it will be expensive! If you have the older PCIe 2 Lane (AHCI) model there are some 3rd party options coming out this Spring so I would wait. So far there is no PCIe 4 Lane (NVMe) option other than Apple. In either case Apple uses a custom SSD so you can't use the now more common M.2 blade SSD's.
If you really want to replace your current HD you have some issues as you will need a special cable harness to replace the HD's thermal sensor. This is what you'll need: OWC In-line Digital Thermal Sensor for Hard Drive Upgrade for 27" iMacs 2012 and Later and you'll need this frame: OWC 2.5" to 3.5" Drive Adapter Bracket to hold your SSD.
Opening up the 'Thin Series' iMac's is a big under taking! Make sure you follow the IFIXIT guides to the letter as you can damage the display assembly quite easily if you don't use the correct tools and technique.
Indice 10
4 commentaires:
Thx for your very informative posts and help
Just a last question- Surely the port speeds arent the limiting factor here- The solid state drive or currently the HDD read /write speeds are the limiting factor
Anyway looks like it might be best to connect an external harddrive to my firewire connectors ( both mine are 20Gb/s) - less risk and hassle
Not keen to go for the flash drive on PC board as thats almost a complete disassemble of my iMac!
par
Yes the read/write speed of a single drive device is less than the the throughput of the SATA III port it is connected to as well as less than the external ports max speed.
BUT! We wouldn't use a single drive device if we want to saturate the link. This is where RAID comes in. By ganging up multiple drives we can increase the I/O speed beyond the limits of a single SATA port {in this case SATA III (6.0 Gb/s)} as well as hit the external ports limit. This would be true with either a HD RAID set or a SSD RAID set.
Here's a good vid explaining the different RAID setups CompTiA Training - RAID
par
Ok thx
how would RAID work? Is it part of the iMAC system/ setup already or is it something that i have to setup.
Also if it is part iMAC setup can i change it or do i need to change it if i replace the HDD with say a SSD?
par
Here's one example of an external RAID enclosure: OWC ThunderBay 4 RAID 5 Edition. We have a few of these setup with HD's as well as others with SSD's.
par
There's a 1TB Western Digital Black and a 24 GB Apple SSD in your computer.
You can essentially replace both of them.
The hard drive is the usual 3.5" SATA slot. While the Apple SSD slot uses a M.2 adapter.
So something like a 850 Pro will do. I would only do this if I was a very experienced computer specialist. Disassembly the Apple Mac 5K is a very risky process and can result in potentially damaging cables or shocking yourself.
iFixit Disassembly guides here:
Hard Drive:
Remplacement du disque dur de l'iMac Intel 27" Retina 5K
Solid State Drive:
Remplacement du SSD de l'iMac 27" Retina 5K
Image iMac Intel 27" Retina 5K Display Disque dur
Tutoriel
Difficulté :
Modérée
1 - 2 hours
Image iMac Intel 27" Retina 5K Display SSD
Tutoriel
Difficulté :
Difficile
2 hours
Indice 3
1 commentaire:
If i replaced both the DD for a 1TB SSD and replaced the 24gb PCIe SSD with a 128gb PCIe SSD what would be the process of configuration? Would I need to create a RAID system or will the fusion drive automatically be created when I re-install OSX?
par
Hey Dan, how do you know what PCIe Lane model you have? I have the 5K Late 2015 27" iMac 3.2 i5 with the 24GB Fusion Drive. I bought this about 10 months ago and thought I was getting 128GB Otherwise, I would got the 2TB one. I think I'm willing to pay for it within reason, but how do I purchase one? Thanks. I been reading your posts and the info you have is very informative.
Indice 1
5 commentaires:
Here is your systems specs: iMac 27" 3.2 GHz i5 - 5K (Late 2015)
This system has a custom Apple PCIe 2.0 x4 NVMexpress interface. Apple sold this system with either custom a PCIe x2 SSD (when intro'ed) or a PCIe x4 SSD (currently sold systems). Sadly, getting a larger SSD for your system is going to be expensive and hard to find as it's a custom part made for Apple. To see what your system has you'll need to look under the System Report section when you open 'About This Mac'
Lastly, this system is a bear to open and you'll need to pull the logic board to get to the blade SSD interface. Here's the IFIXIT guide: iMac Intel 27" Retina 5K Display SSD Replacement
Again, I recommend going with an external RAID drive (SSD being the fastest). Your only other option is to buy a new system that meets your needs and sell yours. But when you do the math I think you'll see the external is the better direction from a cost and risk perspective.
par
I have the PCIe x4 NVMe. My local authorized repair shop can get me a 256 GB for $500-599 (they were not sure on my exact price and I have a buddy who works there).
Yikes! I now have a RAID1 NAS with large HDD's and it's slow, over the network. I use it to store all my raw files and video projects.
So I could move everything over to a Thunderbolt SSD RAID. But, I'd still like to have more SSD storage in this Mac.
I understand the SATA III is slower than the PCIe. But, would this make loading programs and files faster than it currently is?
I usually work from the local internal drive and then move the finished project to the NAS when I am done. I am now leaning towards this and my buddy can install it for me for free. That would be more cost effective than replacing the blade SSD at this time.
So if I replace the internal HDD for a SSD it won't be Fusion drive as both drives are then SSD's. Do you use them in parallel or the blade SSD as a scratch drive? Thanks your for input.
And yes perhaps I should buy a new machine...
par
Nome -
RAID-1 is just disk mirroring which just means it offers a safety net if one of the drives dies. This is not faster than what a single drive's I/O would be. To add to that an Ethernet connection is not very fast when compared to Thunderbolt. It makes a lot of sense for holding your projects that need to be shared. I would recommend moving to RAID-5 on your NAS if you have space for the extra drives if you do a lot of sharing between systems.
What you need is a RAID-0 drive set if you want speed. We have three 4 drive RAID-0 drive sets (both HD & SSD units) The HD RAID-0 is much faster than RAID-1 and our SSD RAID-0 just smokes!
It sounds like we're doing about the same thing here. Yes, swapping out your HD for a SSD will improve performance as the HD is not able to fill the SATA III (6.0 Gb/s) channel unlike the 2.5" SATA III SSD can so its better from that perspective. You'll need to follow the IFIXIT guide here: iMac Intel 27" Retina 5K Display Hard Drive Replacement and you'll need this from OWC: In-line Digital Thermal Sensor for Hard Drive Upgrade for 27" iMacs 2012 and Later as you're taking away the HD's thermal sensor the system requires. And you'll need a 2.5 to 3.5 frame: OWC 2.5" to 3.5" Drive Adapter Bracket.
par
You do need to break the Fusion Drive set before you take the HD out as well as make a good backup.
As to setting up the two SSD's afterwards: You'll need to leave them as discrete drives as you can't run them as a RAID as the I/O channels (& drives) are not the same speed. You'll just bog down the PCIe drive as it can't go any faster than the SATA drive (if you are using software RAID Vs hardware which won't work at all). A Fusion Drive also won't work here as the way it was designed was only when used with a HD/SSD combo. Here the OS can't discriminate between the two SSD's so it can't set the faster drive as the biased drive.
I would setup the PCIe SSD as the OS & Apps drive. Don't put anything else on it as you want the free space for the OS's virtual RAM, Apps cache & paging files. Then run the other for any loose files and your work files.
par
Dan '
Sorry for butting in but how do you 'break" the fusion drive?
I have a 2019 21" iMac with 1tb fusion drive and want to upgrade both the PCIe SSD and the 1tb HD. I thought it would be a simple process but found out like you mentioned the need to "Break" the fusion drive...so for now I've given up, I've searched some on the web and could only find how to repair a fusion drive.
par
hello guys I'm at the exact same problem .
Just one question: Can I remove the SSD blade and the SATA HDD and connect a 1 TB SSD there? Is it possible?
Many thanks in advance
Indice 0
3 commentaires:
This system has two drive ports one SATA (HDD) and one PCIe (SSD). When you buy a Fusion Drive model you are using both of these ports, If you buy a HDD only model then you have an empty PCIe port. If you buy a SSD model you have an empty SATA port.
OK, so you really want an internal upgrade. You'll want to first break the Fusion Drive set (if you have that) before you pull either drive.
Now the question what are you replacing the HDD or the SSD? While tons harder I would replace the PCIe SSD with a bigger unit (1 TB is possible! But very costly and very fast). The easier path is to replace the HDD with a SSD. But its still a big project and not very fast Vs the PCIe port. Doing either you could damage the display in the process. An expensive Opps!
OK, what would I do with such a new system?
I wouldn't open it! I would instead get a Thunderbolt external SSD RAID drive as its cheaper and easier than replacing the built-in SSD and much faster than swapping out the SATA HDD with a SSD.
par
Hello Dan and many thanks for your answer.
Since I have a 1Tb SSD I'm willing to try and replace the SATA HDD by the SDD.
My question is: is it possible? Have been reading a lot and can't reach a conclusion...
par
There is a difference between 'Willing' & 'Wise' ;-}
I don't think it's this is wise move given the amount of work and the risks here.
Yes, you can swap out the SATA HDD for SSD drive. You'll need a few parts to do it besides the SSD. You'll need a frame to hold the smaller SSD drive: OWC 2.5" to 3.5" Drive Adapter Bracket and you'll need this thermal sensor to replace the one thats in the HD for the system to work correctly: OWC In-line Digital Thermal Sensor for Hard Drive Upgrade for 27" iMacs 2012 and Later and you'll need the tool and strips in this kit: iMac Intel 27" (2012-2015) Adhesive Strips
Again, I would recommend you go with an external Thunderbolt2 SSD drive as being a faster and cheaper option (given the risks). Don't for get the SSD here will be slower than what the Thunderbolt connected drive can offer.
par
I have been researching an answer for a few days. The definitive answer seems a little allusive. I am A+ cert. and also have graduated Google training. I don't have any issues performing the upgrade. My question is "Will a 1 T SSD installed in place of the original 1 T HDD that is part of the original Fusion drive work? " As we know, Apple is a little funny about what plays nice with their hardware/software. The logic board has a 32 G Samsung SSProton blade 12x16 pin PCIe 3.0 x 4 interface. Pretty sure this is Apple proprietary. This is the main reason for this question/comment - Will it work if I replace the Seagate 1T HDD (model ST 1000DM003) with a Samsung 1T 860 Pro SSD? I have the sata/thermal cable adapter and frame for 3.5 to 2.5 drive as well as new adhesive strips. Any knowledge I will appreciate.
Thanks Dan for the response. I was afraid that would be the solution. Only problem is the expense of the 3.0 x 4 SSDs. 256 is $400. Gotta love Apple.
Indice 0
1 commentaire:
Hi. I have late 2014 27inch iMac. My hdd just died. Should I replace it or just go external and keep applications and system on the internal 128 ssd? Thanks.
par
Although the suggestion of using an external thunderbolt connected SSD is a good idea, I would like to point out that on the iMac, and possibly all thunderbolt connectors are a poor design. The cable/connector interface is too fragile and loose in my opinion. My external thunderbolt connected drives are constantly disconnecting whenever I tilt the display or move cables near the drive ends. And yes, I have tried multiple thunderbolt cables. So if you want a reliable boot drive, go with an internal SSD.
Indice 0
1 commentaire:
I've never had any problems. Both my iMac 27" & Mac Pro have Thunderbolt connected drives.
par
Re the original posters question, Thunderbolt and replacing the blade SSD in the Mac aside, I’m not sure I saw anything definitive about how to best use the fusion drive if the decision is to replace the HHD with an SSD. Can it still be a fusion drive? Will the mac know to keep the system stuff for booting on the PCI based SSD?
What would happen if I didn’t “break” the fusion before pulling the HHD and simply installed the SSD in the SATA spot. Would it automatically try to create a new Fusion setup? (obviously a backup of the original system would be on hand).
Indice 0
If you want to increase the speed of your iMac, just replace internal HD with SSD, you don’t need to configure or to replace blade (PCIe SSD). You need to install macOS on the internal SSD (the new one). Fusion will not be configured automatically, there is only one way to configure it again and that you can do from Terminal (Internet Recovery Terminal), just type diskutil resetFusion and confirm with “Yes”. Before this procedure, be sure that you have backup of all of your data, because all data will be erased after resetFusion.
Indice 0
3 commentaires:
didnt work on mine. I replace the OEM 1tb mechanical drive with an SSD. Blackmagic speeds were the same or slower than before.
par
Sadly, A dual SSD Fusion Drive is not really better than a HDD & SSD setup. Its best to break the fusion drive set and use the SATA SSD alone, Or if you can upgrade the PCIe SSD to 512 GB or better. Then use it as your boot drive with your apps, and use the SATA drive as your data drive.
par
Hi @danj - None of the iFixit tutorials talk about breaking the fusion drive before replacing an HDD with an SDD. So I have to think many (most) folks following the iFixit tutorial are not doing that. Is the fusion drive perhaps breaking just by virtue of a new SSD drive being installed? Man I thought I was ready to get to work on this tomorrow, but not so sure now.
par
Ajouter une réponse
piet sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 46
Total : 21,332
