Aller au contenu principal
Model A1419 / Late 2013 / 3.2 & 3.4 GHz Core i5 or 3.5 GHz Core i7 Processor, ID iMac14,2
342 questions Voir tout
Is it possible to upgrade the PCIe SSD?
Hi!
I am about to upgrade my HDD on my iMac 27 late 2013 (14.2)
3.4 gHz Intel core I5, Nvdia Geforce GTX 775M 2GB & 24GB RAM
I got the stock 1TB HDD and want to go for a PCIe SSD.
I asked local Apple store if my iMac even support PCIe, but they didn't have a direct answer.
I am looking at the Samsung 950 PRO 512GB M.2 PCIe SSD. Reason for that is because I want a fast drive (Around 800/800)
I know how to change the PCIe, but I haven't got an answer about my iMac will support it. If you know a better supported PCIe please let me know.
Thanks for all answers!
Répondu ! Afficher la réponse J'ai le même problème
Indice 3
Ajouter un commentaire
3 Réponses
Solution retenue
Sadly, you can't use the Samsung M.2 blade SSD in this system. Apple uses a custom SSD (very similar to M.2).
Presently no 3rd parties offer a replacement SSD (advertised as workable). But there are a few people who have used Retina SSD's in the system with success in the older models. OWC just intro'ed PCIe x2 SSD's for the MacBook Pro & Air which I think might work here but I've not done any of this my self.
But before you travel down this path review the IFIXIT guide here: iMac Intel 27" EMC 2639 SSD Replacement as this is a very big job to get to the SSD's slot. You need the correct tools to remove the display assembly it you don't you will damage it which would be a costly mistake.
If you want to try something safer here how about swapping out your HD for a SSHD or a SSD drive. Follow this IFIXIT guide: iMac Intel 27" EMC 2639 Hard Drive Replacement. Even it has a bit of a wrinkle as Apple uses custom firmware on its HD drives so you'll need to use this: OWC In-line Digital Thermal Sensor for Hard Drive Upgrade for 27" iMacs 2012 and Later to replace the missing thermal sensor in the replacement drive (SSHD or SSD)
Frankly, you might just go with an external Thunderbolt RAID drive which will get you a faster interface than the SATA III (6.0 Gb/s) the HD offers. Here's one choice: OWC ThunderBay 4 mini RAID.
Image iMac Intel 27" EMC 2639 Remplacement du disque dur
Tutoriel
Remplacement du disque dur de l'iMac Intel 27" EMC 2639
Difficulté :
Modérée
30 minutes - 2 hours
Image iMac Intel 27" EMC 2639 SSD blade
Tutoriel
Remplacement du SSD blade dans l'iMac Intel 27" EMC 2639
Difficulté :
Difficile
1 - 3 hours
Indice 4
I've asked OWC about PCIe SSD for iMac 21 late 2013, their answer:
I am sorry but we do not carry the correct PCIe SSD for the imac14,1. The only SSD option we offer is to replace your factory HDD with an SSD.
Indice 1
1 commentaire:
Hi
But your Imac 14.2 ?
...correct PCIe SSD for the imac14,1...
par
I replaced the PCI SSD on my late 2014 iMac 5K. It was the factory 128GB that I took out and replaced with a new 240GB OWC SSD along with a OWC 6G 2TB SATA SSD. The reason why I didn’t just get the 2TB PCI SSD is because the older models don’t have the higher PCI x4 interface. It didn’t make sense to get the 2TB AND then have to put something where the failing HD was. So I went with an ALL SSD “FUSION” setup which is possible with Apple APFS format. I am getting about 550 write/690 read and it is MUCH faster than before with the standard 3TB fusion. I also recommend putting new thermal paste on the GPU and CPU when tearing the system down. It was the first iMac I had ever done and it’s not at all difficult like they say. A little common sense and patience goes a long way. In fact, the most time consuming and tedious thing was removing old adhesive residue of the back of the 5K outer edges and on the iMac Aluminium itself! Get iFixit toolkit and it’s super simple with their guides! ANYONE can do it!
Indice 1
Ajouter une réponse
tlagarhus sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 6
30 derniers jours : 18
Total : 13,508
