Aller au contenu principal
La 5e génération du téléphone intelligent Galaxy basé sur Android de Samsung fut lancée le 11 avril 2014. Les améliorations apportées au téléphone incluent un lecteur d'empreinte digitale, une caméra améliorée, un plus grand écran et la résistance à l'eau. Il est disponible en 4 couleurs différentes; noir, bleu, blanc et cuivre.
577 questions Voir tout
Charger Not Recognized, Battery with Yellow Triangle and Exclamation
My wife's Galaxy S5 G900A stopped charging last night. This morning she plugged it in to a different, known good OEM charger and it didn't recognize the charger, stayed at 2% all day. When I got home from work I turned it off and it shows a gray battery and then a yellow triangle with exclamation point. I swapped the battery with one from my phone (exact same phone) and it is behaving the same, but the battery percentage shows 64% which is what my phone showed. I put her battery into my phone and it showed it was 99% charged. I then put the batteries back into their respective phones and now then her phone showed its battery at 99%. I tried cleaning the charge port with alcohol and a toothbrush, then blown out with compressed air, but no change. I tried looking for tests in the diagnostics menu, but didn't see anything related to battery or charging.
The only thing left to try is to reset the phone. It is already on 5.1.1, which is the latest update available. Any other ideas that might fix this problem? If the reset doesn't fix it then I will try a replacement charge port board.
Répondu ! Afficher la réponse J'ai le même problème
Indice 13
12 commentaires
Cool, that's what I figured, was hoping someone could confirm since I didn't want to go through backing up and restoring everything.
par
Yes, you can try that but If you have tried your two options and somehow, it dosnt solve. Visit us at https://cellxperts.net we offer our best cell phone repair Cary NC.
par
my sister had the same problem with her mobile , downloaded power sharing app , and it worked , i guess the problem is in the software , so if anyone could try to update or reset there mobile and see if that would work too or not .
par
Just an idea, try turning it off and removing the sd card and sim card and then try charging, worked for me!
par
getting cross yellow triangle wtto do to slove this problem
par
Voir 7 commentaires en plus
Ajouter un commentaire
15 Réponses
Solution retenue
Charger port daughter board would need to be replaced as from what you said sounds like the charger port has gone faulty. Resetting the phone wouldn't help.
Shorting the two pins corresponding to battery + and - on the phone and not the battery has helped for some people. What this does exactly is create a short circuit without the battery connected to drain any components that may be holding charge on the circuit board that could trigger that battery temperature warning message. Also try cleaning both battery connector contacts if that does not help too.
Indice 6
13 commentaires:
where would i be able to find one
par
http://www.ebay.com.au/itm/Charging-Port...
This is for the SM-G900A variant, make sure you get the correct one or else you will run into reception issues with sim card.
You can also solder the antenna connection golden prong point from the charger port assembly if needed and transfer to the new charger port assembly if it's a different model as they connect differently to the antenna module.
par
I have SAMSUNG P5100 TAB, hard reset (factory reset) help for me. :)
par
*SOLVED*I had red triangle in battery logo when device is off. Device would not charge at all. When i put in charged battery from another device with was getting device over heating, then the phone would power off after couple of minutes.Tried f.reset, different batteries, changed charging port. No luck. But then got another charging port. That done it finally! :)..The first charging port was faulty. Anyone having same problem try it!
par
I had same problem, solution is to take out battery and short the positive and negative connection on phone... if you look on battery it shows you which pins is + and which is - Short the corresponding pins on the phone not on the battery... I used a paper clip, anything conductive will work. Worked immediately and is charging like normal now.
par
Voir 8 commentaires en plus
Réponse la plus utile
removing the battery, blowing out the battery receptacle, then pushing in the connectors a few times to test the spring level to make sure there was constant contact from battery to pins. my phone is now charging. just seemed to be a dirty port or intermittent connectivity. Common problem with charging mobile devices
Indice 8
3 commentaires:
I looked at the other suggestions and they all seemed too expensive, or too risky. I tried yours, and it worked like a charm. The phone is 3 years old now, I guess it's time to upgrade. :-(
par
legend; took me 10 seconds an worked
par
Had same issue with S10e and this one worked after cleaning charge port with a pin.
par
i accidentally fixed it, i go to recovery then clean the cache then change the battery and turn it on, if it never wakes then remove the battery again and change the old one and turn it on again while charging, then its done!
Indice 1
My note 4 would not charge, had the gold triangle - sprayed the charging port with a few blows from a can of Electronic compressed gas and it is now taking a charge.
Indice 1
2 of my spare batteries are showing the grey battery outline, with a yellow triangle and then a small battery with a line through it, when I try to charge.
Both of those batteries were immersed in seawater for about 3 minutes, but dried out naturally inside the hiking pack pockets, until I got to the camp 4 hours later. I'd forgotten they were in the waist belt.
After scratching back the corrosion and cleaning the little connections on the battery and making sure it's in firmly, I've been able to successfully revive both of the batteries.
I also discovered that when one of the batteries moved, the icon popped up again. From this, I think the icon means that the connections are not all completely touching. This may not be helpful for Joe, but hopefully it will be for someone else.
Good luck Joe. :)
Indice 1
1 commentaire:
What if I cannot take the battery out? My phone is a Moto Z. Just barely 2 years old. I just paid it off and I cannot afford another phone right now, any other suggestions?
par
No, these are both G900A phones purchased at the same time so they have the exact same chargers. Besides that, we have interchanged them regularly in the past. The problem is definitely in the phone.
Indice 0
same issue here..i tried different charger ( cable & adapter) but still not charging..
I asked one of my friend..she said that the problem is "Charging Flex" , sounds awesome and expensive..
I can't afford the price..can someone know different solution?? please. tnx
Indice 0
2 commentaires:
PS ..sorry for my bad english
par
The cable is not very expensive at all from eBay. $15 or less as I recall. Unfortunately, I damaged my screen in the process of removing it.
par
Step 2 worked for me. Just used a cotton bud to clean the connections. Perhaps I was just lucky?
http://thedroidguy.com/2015/08/samsung-g...
Indice 0
I dunno mine has a yellow triangle inside the battery part thay shows up when u first plug in a phone that is dead but inside the yellow triangle is a little battery with a slash through it and I jad plugged it up a 3 percent battery and after lole 10 min iy says 50 percent....then tje camera says warning camera failed and then 2 sec later it shut off completely. ......any advice???
Indice 0
I have seen this problem but after a long suffer I decided to change the those ports of the charge, try to solve if not thing are out of control please leave it to the technicians its their jobs before you lose other things.
Indice 0
got one s5 here. same thing after changing couple daughter board. any suggestion?
Indice 0
I have a J7 2016, and for me, problem was fixed by removing and reinstalling the battery again.
Indice 0
You are right , I did the same by removing the battery and shorting the position and negative terminals, it gave small spike of spark and after when I put it back it started to charge. Thank you very much!
Indice 0
I put mine in bag of rice overnight, it's charging now.
Indice 0
Try a different charger. Just because you have another Samsung charger doesn't mean that it is compatible. All of the phones at my house are Samsung (four different models) and some of them are not compatible with some of the other Samsung chargers. Also, if you haven't tried it already, try a different cable in the power block. It may just be an issue with the cable it's self.
Indice -1
1 commentaire:
What Samsung products do you have? If some are tablet and some are phone then some tablets will only accept original cable and wall charger.
par
Ajouter une réponse
Joe sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 35
30 derniers jours : 211
Total : 279,313
