Aller au contenu principal
The LG 60LM6450 is a 60-inch LED television released in 2012. It supports 3D video with glasses at a resolution of 1920x1080 pixels.
77 questions Voir tout
How checked The main bord please?
Bonjour à tous
Quelqu un peut il m'expliquer comment forcer le demain de la carte mère puis celle de la video s il vous plait?
Quelle connexion à quelle pin dois je faire?
Ma Tele ne s allume plus suite à mon lecteur multimédia qui est resté toute la nuit allumé.
Mes condensateurs fusibles.... Sont bons.
Merci de vos réponses
Google translation
Hello everyone
Someone can explain to me how to force the future of the motherboard and that of the video's please?
What what pin connection should I do?
Tele my only illuminates more after my media player that remained lit throughout the night.
My fuses .... capacitors are good.
Thank you for your answers
Répondu ! Afficher la réponse J'ai le même problème
Indice 2
7 commentaires
It is not a 3D be carreful. Thanks
par
@helpthemenace something gets lost in translation. what is going on with your TV? What does it do, or not do? what do you mean by "
It is not a 3D be carreful."?
par
Hy,
I don t understand, speak or write English very wellbut thanks to you r answer.
The model on my tv is not a Lg 60....3D as the model that I took for this discussion. The real model is a LG 32" Led.....
par
My tv does not light up at all, no picture, no sound and no standby light.
In the beginning, the standby light flashed two time and now even the most.
par
I tested and checked the capacitors big, resistors and fuses, they are in good form.
par
Voir 2 commentaires en plus
Ajouter un commentaire
1 Réponse
Solution retenue
@helpthemenace sounds like you are not getting any power to your TV. Check the main fuse. After that, follow the standard repair process.
You can download the service manual from the bottom of this page Sorry, I do not have a french version.
Google Translation
@helpthemenace semble que vous ne recevez pas le pouvoir de votre téléviseur. Vérifier le fusible principal. Après cela, suivre le processus de réparation standard
Vous pouvez télécharger le manuel d'entretien du fond de cette page Désolé, je ne dispose pas d'une version française.
Indice 3
1 commentaire:
Thanks man I like you
par
Ajouter une réponse
The hallowen sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 10
Total : 926
