Aller au contenu principal
This is a Notebook by Acer. Within this document you will have access to guides and a troubleshooting page. This will hopefully allow you to solve issues you may be having with your Notebook.
20 questions Voir tout
Why is my laptop heating up and turning off shortly after?
My laptop seems to heat up very quickly while I use it and it eventually shuts off. After waiting for a bit and turning my laptop on it repeats the same thing.
Répondu ! Afficher la réponse J'ai le même problème
Indice 2
3 commentaires
hey bro i have the same exact pc and face the same exact issue at first i thought it was an OS issue so i put windows 10 but still continues so what i did was teardown the pc completely and whe i reache the processor i cleaned up the dry hard thermal paste and made sure to smear the moist paste on the processor cpu and gpu or if u can u can put new paste it solve ma issue
par
same problem here .. i opened up the laptop cleaned it new thermalpaste (cpu - gpu) replaced the old thermalpads with new ones the cpu fan is working just fine (speeds up speed down) BUT in 10 minutes shuts off even in bios screen ! any ideas? thanks ! the laptop is Acer Aspire 5742
par
The Acer Aspire 57xx series (especially the 5742s) are well known for running very hot, mine shut down a few times as well. You could replace the fan and heatsink (requires system board removal) or set a lower maximum CPU speed in the power plan/BIOS (negating any advantage of choosing an i5 model over a basic Pentium).
par
Ajouter un commentaire
3 Réponses
Solution retenue
Your fan may be failing. I would listen to see if you can hear the fan running when the computer is performing a task. If the fan is silent, it may need replacement. Try following this guide: Acer Aspire 5742 Cooling Fan Replacement
Indice 1
i think you have to clean your Laptop
here a teardown instruction guide for your laptop
http://www.insidemylaptop.com/how-to-dis...
Indice 0
Indice 0
Ajouter une réponse
Claudia Torres sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 22
Total : 578
