Aller au contenu principal
Acer Aspire V3-771G laptop. This is part of the 17.3" screen lineup that Acer offers.
14 questions Voir tout
Why is my screen going crazy with green/purple lines and flickering?
Ok, so I've had this laptop for about 3 years now. It's been working perfectly fine for the most, until my screen decided to start going crazy with colors and flickering. The screen every now and then starts flickering or it start displaying intense green or purple everywhere, but only in certain positions (angle between screen and laptop body). Also I've found a temporary fix, which is to apply pressure at the bottom part of the screen (I have a piece of cloth that I squeezed in between the laptop screen and the body, so that it applies pressure to the bottom part of the lcd)
So I've opened up the laptop to check if there wasn't anything loose or a cable that was badly connected and found nothing.
I've searched online quite a bit a found nothing either; I can't even determine what is causing this (GPU, LCD screen, cables...) so i can't even start thinking what i need to replace, or if it's even worth trying to repair.
If anyone could help would be greatly appreciated.
Répondu ! Afficher la réponse J'ai le même problème
Indice 2
2 commentaires
Same thing wit me except its on an acer monitor connected to my ps4
par
Hi @Roger Rivera,
What is the model number of the Acer monitor?
Can you connect a different monitor to check if the problem is with the monitor or the PS4? Even a TV can be used as a monitor as long as it has HDMI inputs and you have the appropriate HDMI cable to connect the two together.
Have you tried a different cable between the monitor and the PS4?
par
Ajouter un commentaire
1 Réponse
Solution retenue
gus bern possibility of bad logic drivers for the LCD panel is the first thing I would suggest. To determine if it is your LCD, connect an external monitor to your computer. If that shows appropriately then you know the GPU is working and the issue is with your LCD.
Indice 2
1 commentaire:
Thanks, i tested it with a monitor and it worked fine.. guess its the lcd screen then.
par
Ajouter une réponse
gus bern sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 10
7 derniers jours : 34
30 derniers jours : 121
Total : 19,027
