Will not turn on
Will not turn on when button is pushed
Hi,
What is the model number of the desktop?
Try disconnecting everything from the motherboard except the PSU, the RAM and the video card (if not using onboard video), i.e. HDD, ODD, any other cards etc. and see if it starts and if you can get into BIOS.
If the PC still doesn't start, try the paper clip test to see if the PSU starts OK. Here is a link that shows how to do it. If the PSU doesn't start using the test method it is faulty and needs to be replaced.
If the PSU does start OK, then use a DMM's (Digital Multimeter) Voltmeter function to measure the output voltages from the PSU. Also check with the DMM's Ohmmeter function the the desktop's Power button has continuity when operated.
If all the tests prove OK then there is a problem with the motherboard.
model 71G thinkThink center CPU
model 71G Thinkcenter IBM cpu not switching on
Thinkpad R40
Hi @ Sienna Tomkins,
The answer above was for a desktop PC and not a laptop.
Here's a link to the service manual for your model laptop.
Scroll to p.39 to view the options to check out the power system.
Do you get any indications at all on the laptop when the charger is connected and switched on or when you go to start the laptop, power light or any other light etc?
Try removing the memory strips and re inserting, this fixed my issue
Try this first . Unplug the computer then hold the power button down for 60 seconds then release and wait another 30 seconds then hold the power button again for 60 seconds .Now plug in the computer and try to start it . If you have no joy then you need to replace your power supply .
https://www.youtube.com/watch?v=2h_NYl4D...
Hope this helps
Replace the PSU? That's a rather hasty move. It could that the GPIO power button has broken, or many other things.
good point @pccheese I usually throw a power supply in to test on machines I recieve. I always start with a static discharge though but like you suggest it could be a power button . but to be completely honest with you in the 20 some years Ive worked on computers Ive never seen one go bad , not to say it doesnt happen
by the way @pccheese I am very inpressed with how you stuck with the computer build for Sud Tiwari if I could have given more than one vote I would have
Thanks jimfixer!
I didn't mean just the power button, I ment that the power cable may be bad or the motherboard power pins may be loose or something etc.
Hi, I've been having potentially a same same issue. Power supply. After two years of avoiding it, I've finally taken it apart and basically what happened, was a small metal plate ( hinge of the screen section) had unscrewed/-bolted and was pushing against the power connector, and casing, causing this.
After many other checks on everything, here's what I eventually found:
My laptop was working fine, all components fine, and the plug adaptor worked fine. Couldn't get my head round it...
Then, epiphany! The bit you plug into? Where the power gets distributed around the laptop...
There's electrical tape around the wires! . All five power lines from the connector thing to the rest of the laptop (2 red, 2 black, and 1 white) were pulled out, just a tiny bit, but it was within what looks like electrical tape. - so I didn't see this until I'd exhausted every other option and removed the tape from the little metal connector.
Reconnect them, and if everything else works... Hey presto!
Mine belonged to my father in law. It’s a Lenovo Think Centre M58 dead in the water. I went through all the diagnostic advice and determined the power supply was out. I hooked another power supply and unit booted up. I tore the PS down and found several swollen electrolytic capacitors on the PS board. After replacing them the system booted right up.
This should have been much more than a score of zero
Ifixit has no control how people vote or don't vote on answers unless it is a voting ring where people deliberately upvote each other's answers to increase their reputation points, which diminishes the value of the vote score.
Maybe no one as yet has had the same problem as you have found and if they have then maybe they didn't know how to upvote or didn't bother. Who knows.
A lot of the time people who ask questions on this forum don't even bother to respond to the answers provided, indicating whether or not it solved their problem, which can be frustrating sometimes.
C'est la vie
Moderator
Thanks for the explanation jayeff
Dernières 24 heures : 48
7 derniers jours : 290
30 derniers jours : 1,268
Total : 218,046
12 commentaires
Thinkcentre all-in-one will not come on
par anthony maberry
My serial number is
1S3548C8UMJ40G5H
Does not power on.
Answers?
par Mike Smith
Hi @Mike Smith
Did you try the suggestions in the Chosen Solution below, you didn't say?
par jayeff
@jayeff
C8U
par Mike Smith
@jayeff yea I did
Called lenovo tech support and apparently the pc downloaded an update that has caused this issue.
par Mike Smith
Voir 7 commentaires en plus
