Aller au contenu principal
Une enceinte Bluetooth portable fabriquée par Ultimate Ears.
60 questions Voir tout
UE Megaboom will not charge (light still flashing)
I haven't used the Megaboom for 6 months, took it out of storage and used it for the last couple of days while I was working outside (still had battery that lasted two days). Once it went flat, I plugged it in to charge overnight, the white light was flashing as normal. In the morning, I tried to turn it on and it said "Critical battery, please charge". While charging, if I try to turn it on, it just says "Charging, please wait". It still won't work no matter how long I leave it charging, though the white light is still flashing as normal. Is the battery toast? I did use it outside on a day with a lot of fog
Répondu ! Afficher la réponse J'ai le même problème
Indice 47
70 commentaires
for me it was the plus buttom... thanks for the solution
par
I can’t get the white light to turn on at all and all it tells me is “critical battery, please charge. I put it in the fridge last night, I have pushed the minus and plus either one at a time with the power button as well as both at the same time. Still.....”critical battery, please charge”!!! Ughhh! It’s not even a year old. HELP PLEASE! Thank you!
par
Issue I'm having is I plug it in to charge an my light comes on an starts blinking likes it charging an it gives me a message about having critical low battery then after a few seconds the light goes out an it never charges. Anyone have this
par
Mine too!!! I cant get it to actually charge :(
par
That's what I'm dealing with now, out of the blue. It sat out in the sun for a bit this morning and I'm terrified I overheated and fried the battery
par
Voir 65 commentaires en plus
Ajouter un commentaire
8 Réponses
Solution retenue
Same problem. Red light keeps flashing and wont seem to charge.
Hold down the VOL DOWN button and the POWER button for a few seconds until you hear a sound. Then turn it back on.
All fixed! Worked a treat for me :)
Indice 103
57 commentaires:
If not for this fix; I was about to embark on my own electrical mindset, that is very limited in patience! THANK YOU so much for this quick and easy FIX!
Gby
par
Worked! Thanks!!
par
so im trying everything......just now put it in the fridge.......not sure what that will do, however when i have tried to charge by pressing VOL up n down, sometimes it states that its critical, charge, and repeats, at another time i press same buttons and quickly it states charging, however goes quickly back to critical message.......
par
Worked! Thanks. Too bad this tip is not easily accessible in the assistance and FAQ.
par
mine is still not working, the white charging small led is not flashing at all but until now it worked perfectly. I restarted it and did all the process and it’s the same, and I am using the original adaptor and cable to charge it. :(
par
Voir 52 commentaires en plus
My speaker did this. I was able to fix it by resetting the speaker.
Plug it in, and let it charge for a while, just to make sure it has really does have a charge (like half an hour, minimum).
Then hold down the minus button, and the power button for about twelve seconds, until you get a beep.
That's all it took for the speaker to start up correctly.
After that, I did have to forget the blue tooth device, and reconnect new. I don't know if that is part of the process.
Indice 24
28 commentaires:
I never would have thought of combining those steps. Thanks so much! It's charging now!
par
Worked perfectly on my ue roll. Awesome. Saved me buying new speakers!
par
Omg thank you so much!!! This worked for me to!!! I am so happy right now!!!
par
thank you, the addition of forgetting my UE roll helped also,
par
This worked to fix my speaker! Thank you!!
I was sitting here so mad I couldn’t get it to charge, did these steps and went from 5% and won’t turn on to 46% and listening to music! :D
par
Voir 23 commentaires en plus
See this document https://images-eu.ssl-images-amazon.com/...
(because otherwise you won’t believe me).
  1. Plug and unplug power cable 25-30 times, until the power light flashes.
  2. Leave to charge for a few hours
  3. Meanwhile, put Ultimate Ears app on your phone.
  4. Unplug from power, switch on with button on top of Boom unit. Quickly connect with Bluetooth to your phone.
  5. Open UE app, which will prompt an urgent firmware upgrade. Download and install the upgrade (does this automatically).
  6. Never let it get to 0% battery charge again.
Indice 7
4 commentaires:
Hello Nigel,
thank you so much for sharing this document ! This solution helped me bring back to life my speaker!
After 15min (with patience and determination) the charging light started to pulse again!
par
Does this work if the Bluetooth and powerbutton don't flash.
par
Ok - so I get one blink and then nothing - is that the plan?
par
Created an account simply to say THANK YOU for sharing these instructions!! Thanks to you my UE Megaboom has just started charging again for the first time in 3 years. 🥺 Fingers crossed it’ll ne charged tomorrow AM and that steps 2-5 work out too. But in the meantime thank you again! So, so glad that iFixit and friendly helpers like you exist! 😭🩷
par
I finally fixed mine.This is what I did I tried all the reset methods didn’t work ordered a new battery didn’t work put in the fridge still didn’t work was ready to finally call it a loss and decided to look at all the soldering on the boards they all looked good except the small one on the edge underneath the glue like material it had some white powdery stuff on it like when you leave a battery in something for too long so I grabbed a tooth pick and got it all off plugged it in and it started blinking
Indice 1
4 commentaires:
Power cable in and power on. Turn upside down. Sharp tap on hard surface. Sorted. May be dodgy connect to battery.
par
Still not working, blinking red light appears
par
I know it only likes to be charged by the wire and block that it came with
par
BRO this %#*@ speaker (UE MegaBoom) has been down for idek how long and I been looking all over online Dey told me to get a new battery basically so I thought it was OVER for my baby but then looked at those pics opend er up and honestly don’t even know wtf it was that worked but you def help me get there SO THANK YOUUU!!!!
par
I had this issue but holding down power and.volume did nothing unfortunately. Eventually the fix required me to plug in the speaker to charge, after 27 seconds the light stopped flashing, unplug-replug, 27 seconds the light went out. I repeated this maybe 17 or 18 times and eventually the speaker must've had enough charge in it to the beginning charging normally. The remote on feature definitely isn't a great idea if you don't use the speaker regularly.
Indice 1
1 commentaire:
same problem, same solution 🙋‍♂️
par
How do you open up the device to get to those wire controls?
Mine seems pretty sealed.
Indice 0
1 commentaire:
I used a knife and pried it open and I got it fixed I was able to pop it back in with out damaging anything I recommend a YouTube video this is what helped me.
par
My UE Megaboom after months of not using would show as charging for about 10 Seconds with white flashing light. Then light went out and wouldn’t charge after 10 seconds. If I turned on, it said critical battery please charge. After several attempts of removing power lead and reconnecting still same.
Decided to open UE app and it allowed me to connect to speaker. Clicked on the power icon on app and Speaker woke up and immediately started charging and carried on charging. Weird but it worked.
Indice 0
Hi my UE stopped turning on after falling in a swimming pool, and now only the charging light is flashing.. Do you have any ideas what could be the problem?
Indice 0
Ajouter une réponse
Reuben M sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 122
7 derniers jours : 1,052
30 derniers jours : 4,949
Total : 539,829
