Aller au contenu principal
The Expression Photo XP-960 wireless, wide-format Small-in-One printer puts professional-quality photo printing at your fingertips.
23 questions Voir tout
Epson XP-960 prints with blue cast tint on all prints/photos
hi ,
if someone can help me figure this out i would appreciate it
my epson XP-960 printer its printing out with blue cast color on all prints including colored and black white photos , i had just re-installed new inks which are not epson inks but worked with before with no issues , funny thing is when i change my printing settings to print in "plain paper" colors come out ok on my black white photos and colored ones but the printing quality is bad with bands or stripes across , when i change the paper quality to either premium glossy or ultra premium photo paper prints come out with a blue cast , on my colored prints all colors are visible/printed but they have a very strong blue tint they look horrible and the black white come out blue , its really strange and i tried printing with several printing papers including epson premium photo paper , kodak and even HP same thing happens , i did do a nozzle check and cleaned the printing head and all comes out good i just feel im wasting printing paper trying to fix this.
Répondre à cette question J'ai le même problème
Indice 3
1 commentaire
i found that my cartridges were in wrong order(Epson XP-960) put it right then every thing was ok
par
Ajouter un commentaire
3 Réponses
Réponse la plus utile
The first thing to do is run a nozzle check; Epson is the Mercedes of printers in terms of how often they clog with no obvious signs until you run them hard by doing a large run of photo printing unless you let them sit and it tends to be obvious (especially consumer photo models with LC/LM). On pro models, these often have an LK or LLK cartridge with the Ultrachrome K3 printers which is also a troublesome cartridge as it doesn't get used all the time like LC and LM, and Orange on older pro printers. You can do this from the control panel, or the driver. If it has issues here, the head is either flat-out blocked or one nozzle has a few dead lines and it affects photo printing. It MAY clear up with one cleaning, but it seldom does with Epson. Epson printers cannot sit, they have to be run regularly -- people find out as you did a lot more often than I care to admit! I can adopt a nice Epson photo printer with a clog (read: A REAL 6/7+ color model; LC/LM, LC/LM/LK (midrange older), LC/LM/LK/Orange (older) and LC/LM/Red (newer), 9+ on really nice ones which originally cost thousands. CMYK photo printing is a poor color spectrum retrofit added on as a nature of the way these work meant for Grandma to quickly run family photos but otherwise go to the drug store), unclog it, and run it 2-3 times a week and have a really capable photo printer for %#*@ near free, or even free.
If you have access to it you can sometimes clear these types of clogs with programs like Qimage (Windows)/Qimage One (Mac/Windows), but I get not everyone has access to it; it's expensive ($129/250), and costs more then most people paid for their printers, but I own the software for color-critical prints I need to be perfect because I can have things like profiles for custom papers I may not be able to apply to the Epson or Canon driver, like HP photo paper on a Canon Pixma 6 color without the option on the driver side, as well as better prints (or at least near perfect) because I inherited unused boxes, or it was on clearance. Qimage will generate a unclog page which can sometimes repair the issue but it does a number on your cartridges (however, so does multiple cleanings and a power flush which also tanks the remaining capacity of your waste ink pad so much so Epson says it's a last resort and warns about this!!! I recommend against it). Since you're going to use a lot of ink anyway make it hurt as little as possible. You want to run this at the best level to ensure it clears as much as it can. After that, run another nozzle check. If you can afford something like Qimage, schedule it to run those cleaning pages at least once a week to keep the printer from doing this; I usually need to do it every other day where I am due to humidity on sensitive machines like Epsons WHICH DO NOT LIKE SITTING!
Note: Select all of the colors on an LC/LM equipped Epson to ENSURE they run -- it might not clear those if you do not use a non-photo mode and force it to run them since those tend to only be used with photo printing.
If neither works and it's still clogged, you may need a cleaning solvent to unblock the head. Rather than provide a link to have it become obsolete, here's a generic search: Epson printhead cleaner.
Indice 1
Hi,
First I advise against using generic inks as they do fade over time 6-12months.
Next If you have a colour cast leave your settings in Easy Print as Glossy if that's what you are using.
Next go to File-manual print & select "Plain paper-Fine-papersize-untick-high speed.
Then click OK it will then start printing. By unticking High speed you should get rid of any lines.
Let me know how you go. erniegoulding76@gmail.com
Indice 0
This happened to me when I was attempting to print on “Photo Glossy” paper with “Photo Glossy” settings. I also tried Ultra Glossy paper/settings, but I had the same issue.
It took me ages to figure this out, but you need to change the settings to “Premium Photo Paper Semi-Gloss” on both the printer (on the Paper Setting button in front of the printer) and the application you’re using to print. Not all applications have the latter setting (the Photos app on my phone doesn’t), so you’ll probably need to do this from a PC.
Indice 0
1 commentaire:
I tried this and it didn't work :(
par
Ajouter une réponse
hellokitty sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 28
30 derniers jours : 138
Total : 12,984
