Aller au contenu principal
Un système d'alimentation sans interruption (ASI ou en anglais UPS - Uninterruptible Power Supply ), également bloc d'alimentation sans coupure ou onduleur ou batterie de sauvegarde, est un appareil électrique qui fournit une alimentation de secours à une installation lorsque la source d'alimentation, typiquement secteur, échoue.
43 questions Voir tout
Back-UPS Pro 1500 - Error: F05
I'm with an APC UPS, model Back-UPS Pro 1500, which is displaying "F05" error, and constant whistle. To repair I need the electric plate (640-3078A-Z_REV07) and service manual. Thanks if anyone can help me.
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
1 commentaire
Ajouter un commentaire
5 Réponses
Solution retenue
As far as your error, review the guide, here's the error messages:
You'll need to contact APC for the part. But you have a deeper problem as the charging logic is damaged 'F05 - Charge Fault
Indice 4
@caciola the board is a lot easier to find than the service manual. The board is currently for sale at places like this.
Indice 3
1 commentaire:
@oldturkey03 - Good find!
par
Hi I also have F05 error . My local Apc service center tells me the unit is NOT repairable . I am thinkin that if I can locate the charging board/unit I should be able to replace it or have it replaced ?
Indice 0
I have a Back-UPS Pro 900 from 2012 (BR900GI) that has failed with an F05 error. A local APC service center has quoted me $85 (labour included) for the board replacement. I have no idea what the board number for my model would be, but the 640-3078A-Z_REV07 mentioned above seems to cost about $75 second-hand.
I'd love to keep using this device, but given the fact that a repair and a new battery are needed (it's 4 years old) ... buying a new one may seem a better option? I hate it when this happens!!
Indice 0
I simply put in a new battery and problem solved. I tested by putting old, bad battery in another known working unit. It immediately showed F05. New battery tested in both units. No errors. This was in a Pro 1500.
Indice 0
Ajouter une réponse
Sergio Caciola sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 11
7 derniers jours : 43
30 derniers jours : 180
Total : 14,540
