Aller au contenu principal
La Nintendo Switch est une console de jeu portable qui peut être jouée sur un téléviseur via une station d'accueil ou bien seule. Sortie le 3 mars 2017.
710 questions Voir tout
Strip screws? How to fix?
Hi i screwup my side console, by stripping one of the screws. ( i used a y00 instead of a y000). Rubber band and super glue didnt work. To remove glue i use a drill bit (1mm), now there is a counter sunk hole. Ideas?
Répondu ! Afficher la réponse J'ai le même problème
Indice 8
Ajouter un commentaire
5 Réponses
Solution retenue
Sounds like you already have drilled a hole there so I would just get the next biggest drill bit and drill it more. You might even need to use the next biggest bit after that. Once you drill the head off then you can usually take it apart more until you can get to the screw and use pliers to turn it out.
Hope this makes sense.
Indice 7
Try this
Precision Screw Extractor Set
Image Precision Screw Extractor Set
Produit
$24.99
Indice 3
Welp.. Y00 is correct you might have presed a lot. Y00 works for me
Indice 1
So how was this problem solved? I have the same situation. Please help.
Indice 1
1 commentaire:
Needle nose pliers is what worked for me
Indice 0
Ajouter une réponse
jonathan ambrose sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 24
30 derniers jours : 111
Total : 32,306
