Aller au contenu principal
The Acer Aspire ES1-711-P1UV is a laptop developed by Acer. It uses a Windows 8 operating system and an Intel Pentium N3540 processor.
2 questions Voir tout
Acer Aspire Wont turn on
When I press the power button on my machine, the chargingLED turns on and stays solid, but when I press the power button, the blue led turns on then straight off again. If I hold the power button down the blue LED flashes consistently. Does anyone know what is happening ?
Répondre à cette question J'ai le même problème
Indice 0
4 commentaires:
Could be happening lots of things, but first I need to know:
-Was the laptop working properly and then shutdowns while working?? or you shut it down correctly and later it wont power up????
-The battery was working fine??
-Has you try another power cord??
par
yeah it was working perfectly fine . I just shut it down for bed then tried using it the next after noon and nothing. The battery was accepting charge and functioning correctly and I recently got a new power cable today, that's what prompted me to write this
par
same issue here, could you solve it?
par
no. I just eventually gave up. I think its just a dead motherboard.
par
Ajouter un commentaire
1 Réponse
So, as I said before it could be a lot of things and it looks like it might be complicated.
- First, you need to disassembly your laptop, you could do it by following this guide for battery replacement: guide.
- Check if the motherboard if contaminated by dirt and if so clean it up, if the problem persist...
- Try powering up your laptop with the battery disconnected, in order of determine if your battery is in bad shape.
- If the problem continues, you´ll need to test with a multi-meter if you have voltage in the board, and what happens with that voltage when you press the power button. It could be a component in the main-board that is creating a short once it gets voltage.
Indice 0
10 commentaires:
right I can confirm that the battery is holding charges cause the blinking still happens when I remove the power cable. And it does the same thing when the battery is disconnected with the ac adapter still in. Where would be the best place to start from?
par
Quick Update. The Wifi card was shorting the computer out I have since remove it and the laptop powers on the hard drive spun up and then parked but I think that's cause I took out the fan but im not sure ill reassemble and update again
par
Computer powers up, no fan activity but the hard disk spins up. No output to the inbuilt screen and no output to an external one either
par
Did you try cleaning up the RAM memory with an eraser? I also recommend that you do all this test with the hard-drive disconnected (it could get damaged with the in and out of power).
I can´t remember if that model has an 3V battery inside for saving the hour/date and Bios config. Look for it if you found it make a little short between the + and -, to reset Bios by Default
par
How do I make it a little short
par
Voir 5 commentaires en plus
Ajouter une réponse
Charlie sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 13
Total : 1,500
