Could somone please do a repair tutorial on the continuity buzzer
My Fluke doesnt beep when i measure for continutiy but unfortunatly i dont know where to start with the troubleshooting. Regards, Thomas
Hi Thomas!
Have you done the test to change the battery or fuse inside?
iFixit has the available tutorials:
Tutoriel
Difficulté :
Facile
5 minutes
Tutoriel
Difficulté :
Facile
7 minutes
Hy ,
really cool that you anwsered so fast. Well the battery is ok as i can measure Volts and Ohms and other stuff. Just the buzzer doesnt work. I will change the fuses next and let you know if it works. Thanks so far.
Regards, Thomas
With pleasure, tell us what happens after the fuse is replaced.
Hey guys sorry that it took so long to anwser. i ended up bringing the fluke to a repair shop as replaicing the fuse didnt help, anyway thanks a lot for your help :-)
I know this is late, but there is a small disk that goes behind everything. You have to get a replacement for it. If everything works fine minus the noise for the continuity test. You are missing the disk. I am trying to find it myself.
The small metal disk is a buzzer or sounder. Check if it works with a Signal Generator if you have one. It will sound if you apply a 3KHz Square wave 3 to 4v PtoP.
If it does not it is dead, replace it. If it does then the connections to the disc are broken somewhere and you need to repair that. Be sure you have not turned OFF the buzzer somehow. Some Flukes have that feature.
I fixed my Fluke 87 RMS buzzer by replacing the small "pegs" that make contact between the circuit board and the plastic plate with the piezo disk with small snips of wire (used old thermostat wire). I don't think either original peg was making contact. I did do the test on the circuit board to ensure I had the 3KHz Square wave 3 to 4 volts as stated by Jim Calvert. My meter still had the piezo disk and the plastic strap that holds it in place. The thermostat wire is just the right size to fit in the holes where the pegs were (I broke them off with my finger to remove them). The wires I used were only about 3/16 in. I used needle nose pliers to flatten the ends of the wire after putting it in the plastic, then careful put everything back together. My buzzer stopped working years ago, and it is nice to have it back I couldn't find the conductive pegs anywhere, so I hope my fix holds ups long term. I know my meter is old, but it works great for what I need it to do.
There is a small plastic strip across piezo disk with two small "pegs". These do break with time. The strip can be ordered through Fluke. Not cheap but will restore buzzer.
822791 FLUKE 87-8007 ,CONTACT,ANNUNCIATOR 1 10.89
Dernières 24 heures : 4
7 derniers jours : 12
30 derniers jours : 43
Total : 1,664
1 commentaire
I have a fluke 77 series 2, when I put it to measure continuity it gets an infinite beep, what can it be?
par Enzo
