Monitor turns off randomly.
I have a BenQ 27 inch monitor. I hook the monitor to my laptop to have a larger display. It was working fine for a year.
The issue:
Recently the monitor shuts off every 1~2 minutes, and after another 1~2 minutes turns back on. This cycle goes over and over. A few observations are as follows.
- During the turn off, its green power button also turns off (the power button will not become orange). That means, it is not just the display that goes off, but it seems the whole power of monitor goes off. I suspect this is a power issue.
- During the time when the monitor is on, there is no problem with the display itself. I doubt it this is the issue with the graphic card of a driver related issue.
- Changing the power cord, or power outlet does not help. It is also connected firmly.
- Changing the cords of either VGA, HDMI, Display port and their connectors does not affect the issue.
- Using a different laptop/PC or operating system connected to the monitor does not affect this issue. Also, my laptop works fine with other monitors.
My attempt to fix it:
I suspected this might be a bad capacitor on the power board. I neither found a bulged capacitor by a visual inspection, nor there was a smell or noise from capacitors. However, I ordered a couple of capacitors online with the same specs, and replaced some of them on the power board. The issue still persists.
Question:
I do not think I am able to find which component on the board is causing the issue. So, I want to just order a whole board from a vendor.
Before spending time and money on ordering a board, I want to (almost) make sure if it is the power board issue at all, or maybe the main board (graphic board) issue?
Thanks.
13 commentaires
i have the same problem tho, when playing monitor turns randomly off
par popa2k
did you manage to find the problem? i seem to have exact same problem, though i do lick the over heating idia as some of the solder joints were burnt, im going to try run the monitor with no back on it and see if that fixs the prob if it does i will repot back though this will not be a fix and ill have to think of a way to incorprat a fan in the case lol
par pog
im going to start a new thread with my prob and solutions as whith the back off and boards exposed it still blinked in and out however with a fan blowing on the exposed boards it did stay on though got very buzzy and after several minits horazontal lines were blurung the screen ill link to my post later maybe it will help :) btw arcad3blood nice idia on the fan :)
par pog
Unfortunately, I was not able to find the cause of the issue. Besides replacing some of the capacitors myself, I eventually ordered a new power board from Benq customer service, and it did not fix the issue either. The issue could still be from other components of the power board, or from the graphic board. Anyhow, I did not spend more money on replacing other components as it eventually becomes more expensive than buying a new one. I got another new monitor.
par Sia
intermitent power on and off veiwsonic va912
par pog
Voir 8 commentaires en plus
