Aller au contenu principal
Information and repair guide for the Frigidaire FFU20FC4AW, a vertical door-access freezer from 2002 with automatic defrost and an anti-sweat heater switch. This page covers information for model numbers matching the pattern FFU20FC4AW*.
1 questions Voir tout
Frigidaire upright freezer not freezing
I removed panel inside the freezer, fan is spinning, coils are frosty but not overly frozen. Defrost thermostat and heating element appear good, did not put meter on them, since coils were merely frosty. Nothing seems to be protruding to keep the door from fully closing. Temps fluctuate between 35-50°. Where do I need to start looking?
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
2 commentaires
I have the same model and everything. I changed the Thermostat, still not cold at the top of the unit but freezing at the bottom. I changed the defrost timer, still same issue. I tried a new Thermistor or whatever is attached to the coils, same issue. Defrost heater works as I have seen it in action. Only top half of my coils are frosty. Fan works fine. I cannot figure it out. I do have some oily residue around the lines. I am just lost on this one though. I cannot find my condensor coils; i think they are sealed behind the back wall of the unit. So I cannot clean them. Nor do I know if a fan exists to cool them down. Any help that can be afforded is welcome.
par
I have the FUG14DHBRWW freezer and only the bottom tray and shelf above it are freezing the food. Anything on the door and anything above the bottom shelf is cool to the touch but far from frozen and not as cool as the refrigerator. I have it in a well vented area but it does get as hot or cold as t he outside temperature as it's on my screened in room/porch. I assumed the door was not shut and that was the cause of the now unfrozen food. We removed all the food cooked it bagged it and let it become room temp before putting back in the freezer. I could not hear or see any fan running. After a few weeks it started to make a noise. When I felt the back of the freezer it seemed to be a fan hitting something. I smacked it with my hand and it sounded like it was ice. Now I can hear the fan and am anticipating my issue solved.......although I still wonder why it happened to begin with. I did the paper trick with the door seal and it pulls out with little to no effort
par
Ajouter un commentaire
5 Réponses
Solution retenue
Hi @tommysparks1 ,
What is the model number of the freezer?
Are there any oily residues on the condenser coils or near the compressor which may indicate a leak of refrigerant? Also are the condenser coils clean and free from accumulated dust etc?
Interesting that there is ice on the evap unit at 35F. Ice only forms at 32F. Are the temps shown found using a thermometer or from a display panel if it has one?
Test the door seals by placing a sheet of paper between the door and the door jamb and with the door closed try to pull it out. It will come out with a bit of effort but not that easily and it definitely should not just fall out. Try this at various places around the door, top, bottom and both sides.
Indice 3
6 commentaires:
Model Number FFU20FC4AW2 Manufactuered in 2002. I do not see oil around the compressor or lines. Compressor is 125-130° when it is running, is this normal? I tested the 12 uF capacitor, it is good. I checked ohm in the starter, I read, 63,64,5 ohms. I have had one digital thermometer (Taylor 1443) hanging in the freezer. Now that you are questioning my thermometer, I just added a second (Taylor 1443) about an hour ago. One reads 49° the new one reads 10°. Humm, not what I expected. Ok, just checked the voltage on the 3v battery in the original thermometer and it reads 1.5v. I put a new battery in. 15 min later, one reads 19°, the other reads 18°, not the zero that I hoped for but this might be ok. The door does not do the suction thing like it used to when you shut it. I did the paper test and it pulls out with a little resistance. When I shut the door, it stops right before it completely closes, you have to push it. Maybe hinge adjustments or seal? Thanks Jayeff
par
Hi @tommysparks1
Compressors are designed to be able to run for long periods of time. Have never thought about their actual running temps unless they were too hot to touch. This may be of some help with that.
18 F is still too warm though.
Did you check the seals on the hinge side to see if they're OK as far as shape etc goes in case they're causing the door not to close properly i.e. twisted or distorted etc.
Stupid idea but can you prop the door shut so that there is a bit of pressure on the seals and then check the temp after a few hours (to give the freezer a bit of time to cool evenfurther)? That may give a clue.
Is the compressor running continually trying to get the temp down or does it stop and if it stops (for only a little while and not for the longer auto defrost cycle ~15 minutes) what is the temp then? It may be a faulty thermostat that is telling the compressor to turn off when it shouldn't.
Just some more thoughts
par
I checked temp again this morning and it was zero. Now 6 hours later, they both read -2. So I guess I have a problem with the door seal or hinge alignment, the door likely did not close all the way and caused the ice cream to get soft yesterday . I used a thermometer with a weak battery and got some bad readings. I was literally going to get a new freezer first thing Monday morning. Thanks for questioning my thermometer! I really appreciate your help jayeff!
par
Hi @tommysparks1
Glad that it mostly works OK now, except for having to ensure that the door is closed properly every time ;-)
-2 F is good for a freezer (at least where I am, 0 F is the set temp for most home freezers so getting -2 F is even better although this could just be the difference between your thermometer and the thermostat but it is still 32-34 deg. below freezing point).
It may be the seals or alignment as you say but since it reached the "set" temp maybe all it will take is to make sure that the door is closed properly.
If you think that you need new parts either hinges or door gasket (part name for seal), just search for "FFU20FC4AW2 parts" to get suppliers that suit you.
There's partselect.com, searspartsdirect.com, repairclinic.com and appliancepartspros.com just to name a few of the major ones.
The first two have parts diagrams which help to give a general idea of all the parts location etc.
Cheers
par
My unit stopped freezing, flashing green light. Warranty repair replaced the circulation fan and added seal tape to cover. All good till bottom of door seal became unseated, and the sensor magnet dropped out of its holder. No magnet, no positive door seal. And make sure door gasket is seated correctly. Again all good till flashing green happened again. suspect circulation motor.
par
Afficher 1 commentaire en plus
@Shawn Bingaman
The door seal should be pressed against the door jam to ensure a tight seal to prevent cold air from escaping or more to the point prevent warmer moist air from entering.
Warmer air entering the compartment can create more ice on the evaporator unit in the freezer compartment which may impact on the fan.
Check the seal all round, top bottom and both sides to ensure it’s not split, warped etc. If it appears to be OK check the door hinges to see if the door is aligned properly
Did you mean a GE FUF14DHRBWW freezer?
Part 1 shows the door seal (gasket)
Indice 1
It sounds like the compressor is running and it seems to be working somewhat. Even if the seals were bad it would still try to work. So it appears you may have two issues. One is the leaky seals so you’ll never seem to actually reach a freezing temp. Two, is it sounds like the thermostat is malfunctioning. It is the thermostat which regulates the temperature. If that’s not working properly you’ll have the issue you have now.
Indice 0
Hi @josnor ,
Just verifying that it is a Frigidaire Freezer model # FFU20FC4AW2?
Only asking because looking at the parts list from two part suppliers, the condenser coils are on the outside at the back of the cabinet. (see System parts diagram). Because they are exposed to the open air there is no fan necessary to cool them down
supplier 1
This supplier shows the condenser coils in the System parts diagram, even numbers it, but doesn’t list it in the System parts list, although if you search for condenser in the Search by Keyword search box below the parts diagrams, left side of page, it shows that it is available as a special order
supplier 2
This supplier actually shows and lists the condenser coil as part #1- system parts diagram
Two things you mentioned are of concern.
First is “Only top half of my coils are frosty”. This may indicate a blockage in the evaporator unit.
Second is “I do have some oily residue around the lines”. Oily residues may indicate of leak of refrigerant. There is a special oil added in with the refrigerant in the sealed system to lubricate the compressor. If there is a leak then the refrigerant will escape undetected to the air but the oil will leave a trace.
A lack of sufficient refrigerant will cause cooling problems.
You may have to get a licenced refrigerator repairer to check the sealed system. They have the equipment necessary to check the high/low pressures in the sealed system which will indicate what and where the problem may be. I say licenced because depending on your location this is because of the environmental regulations regarding the handling of refrigerant gases. Where I am you cannot even buy refrigerant gas without a licence if you wanted to recharge a sealed system yourself.
Indice 0
FRIGIDAIRE Model : FFFU20F2VW0 Serial #: BB03602068 Part: 5303918891 ASSY FRONT COMPLETE Installed Part: 5304529281 BOARD ASSEMBLY,MAIN,ERF300,W/H Installed
My 1 1/2 year old freezer stopped freezing from the top to about the basket on the bottom and the next shelf up. Above is what was replaced by electrolux as it was under warranty. Hope this helps someone.
Indice 0
Ajouter une réponse
Tommy sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 22
7 derniers jours : 133
30 derniers jours : 541
Total : 38,588
