Aller au contenu principal
All screwdrivers manufactured by iFixit and sold on iFixit.com
22 questions Voir tout
T6H, T7H, T8H, T9H, T10H - vs - TR6, TR7, TR8, TR9, TR10
Is the T6H, T7H, T8H, T9H, T10H -bit identical to the (torx security) TR6, TR7, TR8, TR9, TR10 -bit? And what is the reason for the difference in naming?
I’m deciding whether to buy a precision screwdriver kit.
T[…]H:
vs TR[…]:
Répondu ! Afficher la réponse J'ai le même problème
Indice 3
1 commentaire
The only difference is the security screws have a pin so the Torx TR bit have a hole to get around the pin, unlike the standard Torx drivers which don't.
par
Ajouter un commentaire
2 Réponses
Solution retenue
The difference is the T6H is the torx security bit, and the T6 is the regular torx bit. I think you can use the torx security bit in the regular torx, but you definitely can’t use the standard torx driver in the security screw.
Indice 2
6 commentaires:
My question is if (for ex.) the bit labeled as T6H is the same as one labeled TR6.
par
@Professional Amateur They’re not. The H one is the security bit, the non H one is the standard bit.
par
It's a matter of terminology, just observe the bit itself -- does the Torx bit have a hole in it? Then it's a Torx security bit. T6H (H probably means 'hole') and TR6 (tamper-Resistant) are equivalent.
par
It looks like the answer is yes but no one is giving a definitive answer. Simple is a TR8 the same as a T8H?
par
@oldturkey03 Seems like you are wrong if you look at the post below. And you did not give a definitive answer either.
par
Afficher 1 commentaire en plus
Hello,
I just bought a set containing T6H and T8H bits and I can confirm they fit the TR6 and TR8 Torx Security Screws from the Mac Mini Late 2014 Hard Drive Replacement instructions. The T#H bits have a little divot in the center that accommodates the nib in the center of the security screws.
Does the "R" in TR6 mean "Regular"? Or does the "R" designate that it's a security screw? I have no idea and I wonder if some of the confusion on this thread stems from that "R". Regardless, the T#H bits do work with security screws.
Indice 1
Ajouter une réponse
Professional Amateur sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 23
7 derniers jours : 130
30 derniers jours : 626
Total : 17,852
