Aller au contenu principal
Released March, 2016. Identified by model number: 15-cd040wm
6 questions Voir tout
Help with Laptop Keyboard Replacement
I'm having trouble finding a replacement for my laptop's keyboard. All the keyboards I've found have a similar ribbon cable but seem to have more connections than the one installed in my laptop.
The ribbon cable for my laptop
The ribbon cable of the keyboards I found online | Image 2
Do the extra connections mean that the keyboard won't be compatible with my laptop even though the ribbon cables plug into the motherboard?
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
Ajouter un commentaire
2 Réponses
Solution retenue
Update: I ended up buying that replacement keyboard because it was that or throwing out a otherwise functional laptop. And the keyboard and the backlight work!
I had to hot glue and tape it in because the original keyboard was attached with plastic rivets that break when you remove it. Besides that it was a pretty easy repair. I'm updating this post just in case someone else has a similar problem.
Indice 0
Réponse la plus utile
@sidd065 looks like the connections on the ribbon cable as well as on the connector side, are all different. I would not chance it. What is the exact model of your Laptop. Maybe we can help finding out more about this.
Indice 1
2 commentaires:
Yeah, it won't work. OP's backlit configuration is difference since the strip is split from the main wire; they need a matched replacement.
I've never tried a HP backlit KB delete because that makes zero sense as it's a dumb downgrade. I've ripped SureView out of SV notebooks and HC editions with bad screens, so I know that works.
par
@oldturkey03 It is a HP Pavilion Power 15-cb004na. Its an older laptop with a confusing name so finding replacement parts is rather difficult.
par
Ajouter une réponse
Sidd065 sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 20
Total : 393
