Aller au contenu principal
The Acer Aspire 5 (Model Name: A515-51G-56V1) is a laptop manufactured by Acer Inc running on Windows 10. Released in 2018.
12 questions Voir tout
Why is my screen flickering after changing it?
I changed my screen recently and since then the screen goes on and off randomly. I seems to be a bit better when I press it. If I plug back the previous broken screen it doesn't flicker at all. I updated the drivers. I going crazy, do you have any idea ? Thanks
Répondre à cette question J'ai le même problème
Indice 1
Ajouter un commentaire
1 Réponse
Réponse la plus utile
That's signs of bad connection between the screen and the motherboard. If cable from new screen isn't working properly, you can detach it on the back side of the screen and the motherboard and plug same cable, but from old screen. Connector on screen should look like this, in attached image. This cable should be detached and plugged in carefully, cause it's can broke easily
Indice 2
1 commentaire:
Thanks Alex for your answer!
I'll give it a try but I have to find another cable as the new screen didn't come with a new cable.
Also, I tried a different new screen and it flickers as well. However, when I plug back the old screen with the same cable it doesn't flicker. Weird.
Thanks for your help.
par
Ajouter une réponse
Sylvain Hochede sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 9
30 derniers jours : 13
Total : 502
