Aller au contenu principal
SEAT construit des petites voitures économiques pour le marché européen.
18 questions Voir tout
Engine noise from 2011 Seat Leon
I have a 2011 1.6 Litre Seat Leon Diesel. The engine has been louder than usual and there is a vibrating when sitting in the car. The vibrating is worse when the clutch is depressed. Does anyone know what could cause this?
Répondre à cette question J'ai le même problème
Indice 1
Ajouter un commentaire
1 Réponse
Réponse la plus utile
@johndoe177 this "The vibrating is worse when the clutch is depressed" could be a bad bearing or a worn pressure plate. Check your clutch a bit better and see if the noise sounds more like a grinding coming from the clutch area. Of course it could also be a vacuum leak as well as 100 other things that may cause your engine to develop a vibration. Consider having the OBD scanned to see if it throws a code.
Indice 3
Ajouter une réponse
John doe sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 12
30 derniers jours : 31
Total : 622
