Aller au contenu principal
{A1989 / EMC3214} — Sorti en juillet 2018, le MacBook Pro 13" contient des processeurs quad-core i5 et i7 et une carte graphique intégrée Intel Iris Plus.
205 questions Voir tout
When I open the lid, screen fades to white and goes flickery
When the lid is opened past 30 degrees the screen starts to fade to white and flickers untill you can barely see what is on the screen.
When you close the lid back to 30 degrees its like a switch and screen comes back to normal.
Otherwise works perfectly. Works to external screen ok.
I know older machines had probs with screen cable but they seem to result on screen going black.
Thanks in advance for any help
2018 macbook pro A1989 i7 2.7GHz 16Gb ram
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
Ajouter un commentaire
2 Réponses
Solution retenue
Yes, the older 2016/17 systems had a backlight cable issue what was called FlexGate!
In your case the issue is within the T-CON board and the LCD panel. There is a set of cables which connect between them so the board can paint the screens image. The reset signal is not working so the screen just additively adds the following image on top.
Sadly, you’ll need a new display assembly MacBook Pro 13" Retina (Mid 2018-Mid 2019) Display Assembly and here’s the guide Remplacement de l'écran du MacBook Pro 13" Touch Bar 2018
Image MacBook Pro 13" Retina (Mid 2018-Mid 2019) Display Assembly
Produit
$479.99
Indice 1
Réponse la plus utile
Hi
I believe you have a issue called "flexgate" ;-{
Flexgate is where the screen cables start to break apart and perish
I was testing a A1989 MacBook Pro's screen a day or so ago and it had the exact same issue as what you are reporting
unfortunately the only long term fix is to ether have the display cables replaced which hardly any people do or have the display assembly replaced
Hopefully this helps
Any questions please ask
Indice 2
3 commentaires:
I thought the 2018 model had been fixed?
I thought I would probably need new screen, ouch!!
Oh well better dig deep and shell out.
Thanks for replies
par
@alanhancock31
Yeah they ”fixed” it
In all fairness on the 2018 and above they did make the screen cables longer to try and avoid the issue but it unfortunately does still come about it’s just not as common
par
@hellomacos @alanhancock31 - Here’s a good write up on FlexGate https://www.ifixit.com/News/16943/macboo... and the 2018 onward systems don’t encounter the issue as you can see better explained here https://www.ifixit.com/News/13979/apples.... That still doesn’t mean you still can’t encounter a backlight issue! A good bang along the black clutch cover or something wedged between the uppercase and the display bottom edge (chin-plate) which is a thin piece of glass which covers the cables going to the LCD panel can be damaged. The backlight goes out, black not white
par
Ajouter une réponse
alanhancock31 sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 32
Total : 221
