Aller au contenu principal
An electronic toothbrush manufactured by Philips and released in 2007. Five different modes, designed to clean teeth more efficiently.
7 questions Voir tout
Beeping, one long, two short
My trusty Sonicare has started beeping in a repeating pattern while charging. It still works, but only occasionally. Is this fixable or do I need to buy a new one? It is by far the best toothbrush I have ever had, so I don't want to just discard it without attempting a fix or knowing I need a new one.
Répondre à cette question J'ai le même problème
Indice 3
1 commentaire
Mine only works for about 2 seconds and stops
par
Ajouter un commentaire
1 Réponse
Réponse la plus utile
Try this fix first. Hold down the SILVER button for 5 seconds while the toothbrush is on the charging base. If the fix works, it will fix the problem immediately like magic.
If that doesn't work, try this:
1) remove the brush head.
2) use a screwdriver in the base and turn 1/4 turn
3) push out assembly from the top
4) dry the inside of the base handle. allow it to air dry
5) allow the switch to air dry
6) reassemble
Indice 1
6 commentaires:
my sonicare doesn't have a silver button, only a green one. And no screwdriver has been able to turn the base 1/4 turn. Any other ideas?
par
Mine also does not have a silver button. I think it depends on the model. I just held down the power button while the brush was on the charging base, per Hayden's instructions above. It responded with a series of vibration signals, then the beeping series stopped "like magic." So far, so good.
par
None of the above works
par
None of the suggestions work. Tge beeping is driving me crazy.
par
None of the suggestions work. The beeping is driving me crazy.
par
Afficher 1 commentaire en plus
Ajouter une réponse
Don H Smith sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 61
7 derniers jours : 565
30 derniers jours : 2,226
Total : 13,625
