Aller au contenu principal
La quatrième génération de Fairphone, fabriqué par l'entreprise sociale du même nom. Sortie en octobre 2021.
16 questions Voir tout
Phone call or receive problems!
Everytime, I make a phone call or received a phone call. There other side how call me is not able to hear my voices. Help to fix FairPhone 4. Do you think is the speaker part is the problem?
Update (05/13/23)
Which part?
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
1 commentaire
https://www.google.com/amp/s/amp.theguar...
Which part?
I try to put the image is not working well. So, put a link.
par
Ajouter un commentaire
2 Réponses
Solution retenue
No you have a problem in your Microphone, you should replace it.
Indice 0
1 commentaire:
The speaker and microphone are the same part or component?
par
Réponse la plus utile
Hi @erickonix,
Can you be heard OK when using the phone in loudspeaker mode when on a call?
Is the phone in a protective case at all? If so remove from the case and check if it now works OK.
Try using a vacuum cleaner to clear the voice inlet hole located on the bottom edge of the phone in case it is blocked with lint etc, and check.
If still no good it may be the microphone in the phone.
Indice 1
14 commentaires:
Even with or without the phone case still same problem. Where is located the microphone?
par
@erickonix
Did you try clearing the voice inlet hole using a vacuum cleaner, you didn't say?
par
Can you show me as pictures where is located?
par
@erickonix
Can't find any pictures but there are two small holes on the bottom edge of the phone for the microphone.
Do not stick a pin in them to see if they're clear as you may damage it
There's also a small hole at the top for another microphone which is used for loudspeaker calls
par
In bottom part of FairPhone 4. In the center bottom is USB type C. At the right side of USB type C have 3 holes. At the left side is have small hole. So, which part is the microphone?
par
Voir 9 commentaires en plus
Ajouter une réponse
erickonix sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 9
30 derniers jours : 55
Total : 828
