Aller au contenu principal
The HP Compaq 8200 Elite is a small form-factor workstation-class desktop PC aimed at higher-end office and design work. It has a fairly repairable design with emphasis on allowing technicians to quickly swap out drives and cards.
22 questions Voir tout
My computer is not displaying on the screen memory stick is ok
How do i troubleshot this problem
Update (06/27/23)
Tried the prossesor it is heating up, when i remove it it is beeping but when i remove the memory stick it is not beeping. I dont want to decreare the motherboard is not ok but i rearly want your troubleshooting options. Please assist
Répondre à cette question J'ai le même problème
Indice 1
2 commentaires:
@peternjogukuria "prossesor it is heating up..." hot hot does it get and do you have a fan in your system? does the fan work? "when i remove it it is beeping" why would you remove it and yes, it is supposed to beep. "when i remove the memory stick it is not beeping" how many memory sticks does your computer have? What type of memory? Now, the most important part. With your processor properly connected and your RAM installed, what happens when you turn the computer on?
par
RAM may be damaged. What is the beep code when powering it up? (the number/sequence of beeps)
par
Ajouter un commentaire
2 Réponses
Not open computer I kown his started
Indice 0
My cpu in not screening on monitor and beeping sometime then turning fan
Indice 0
Ajouter une réponse
Peter njogu kuria sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 7
Total : 212
