Aller au contenu principal
Tutoriels de réparation et information de démontage pour réparer les PC portables de nombreuses marques.
19257 questions Voir tout
comment retrouver les schémas des cartes mere des PC?
Bjr. après mes précédentes questions sur la Puce 3v5v. je reviens cette fois-ci pour demander si vous pouvez m'offrir les Sites Internets où je peux commncer à trouver les schémas électroniques sur le fonctionnement des cartes mere des ordinateurs.
Enfin, Quelles références des données placée sur les cartes mere faudra-t-il retenir pour avoir ces schémas? merci
Répondre à cette question J'ai le même problème
Indice 1
Ajouter un commentaire
3 Réponses
Réponse la plus utile
@patshomwz the actual laptop description is usually irrelevant. It is always advisable to have the actual motherboard make and model description. If you only have the make and model of the laptop, you will have to spend a lot of time to determine which board is for a specific laptop. Once you have the actual board identifier, you can do an online search. As was already mentioned, all of those schematics are copyrighted. They are considered intellectual property You are not supposed to have or share any of those. Do most repairers have them? Absolutely. There are a lot of foreign countries that are not very particular about copyright laws and thus the sale of those is tolerated. Even if you buy a schematic, it is still not okay to have it, according to Apple and others. ;-)
There are a lot forums that will share schematics and a few are even specialised for different laptop makers i.e Apple, Dell etc. Most of these sites require you to subscribe to them. Some require a monthly fee others are free. Be warned, there is also a lot of trash out there. If you do it long enough you will quickly determine which sites are to be avoided.
Collect as many schematics as you can and store them in a way that you can find them at a later date. It's no fun to dig through a couple 100GB to find a file. Trust me on that. Been there, done it :-)
Also, schematics are really only half the battle. Most motherboards now do no longer have board designators printed on the board. For those board you do require a boardview that will show you where a specific component is located. Not all schematics you'll find have both, the schematics and the boardview.
Remember that none of the computer makers like HP, Dell, Lenovo, Apple, Asus etc. fully support the Right-to-Repair. They are NO help at all for that. They have gotten better in supplying manuals for the teardown of their computers and the exchange of parts, but not a boardlevel repair. Toshiba got to be the worst. That company is absolutely paranoid about self repair. They are known to use their army of lawyers to go after repairers. That is one make of laptop that you want to stay away from.
There are literally hundreds of YT videos about repairs that can probably teach you a few things. There are also a few online course (fee for service) that teach the basics. You need to walk before you can run. Start with the basics. Also, there are a lot of opportunities in you community to learn things. Never underestimate repair cafe's and community fixing events. Get involved and watch and learn from those that are good at it. This will of course depend on where you live etc.
I do hope this helps a bit to navigate through the murky waters of schematics :-)
Repair is War on Entropy!
Translation
@patshomwz la description de l'ordinateur portable n'est généralement pas pertinente. Il est toujours préférable d'avoir la description de la marque et du modèle de la carte mère. Si vous n'avez que la marque et le modèle de l'ordinateur portable, vous devrez passer beaucoup de temps à déterminer quelle carte correspond à un ordinateur portable spécifique. Une fois que vous avez l'identifiant de la carte, vous pouvez effectuer une recherche en ligne. Comme nous l'avons déjà mentionné, tous ces schémas sont protégés par des droits d'auteur. Ils sont considérés comme de la propriété intellectuelle. Vous n'êtes pas censé les posséder ou les partager. La plupart des réparateurs les ont-ils ? Absolument. De nombreux pays étrangers ne sont pas très regardants sur les lois relatives aux droits d'auteur et la vente de ces schémas est donc tolérée. Même si vous achetez un schéma, il est toujours interdit de l'avoir, selon Apple et d'autres ;-)
Il existe de nombreux forums qui partagent des schémas et certains sont même spécialisés pour différents fabricants d'ordinateurs portables, par exemple Apple, Dell, etc. La plupart de ces sites requièrent un abonnement. La plupart de ces sites exigent que vous vous y inscriviez. Certains demandent un abonnement mensuel, d'autres sont gratuits. Attention, il y a aussi beaucoup de déchets sur ces sites. Si vous le faites suffisamment longtemps, vous déterminerez rapidement les sites à éviter.
Rassemblez autant de schémas que possible et stockez-les de manière à pouvoir les retrouver plus tard. Il n'est pas amusant de fouiller dans quelques 100 Go pour trouver un fichier. Croyez-moi. Je suis passé par là :-)
En outre, les schémas ne représentent que la moitié de la bataille. La plupart des cartes mères n'ont plus de numéro de carte imprimé sur la carte. Pour ces cartes, vous avez besoin d'une vue de la carte qui vous montrera où se trouve un composant spécifique. Tous les schémas que vous trouverez n'ont pas les deux, le schéma et la vue de la carte.
N'oubliez pas qu'aucun des fabricants d'ordinateurs tels que HP, Dell, Lenovo, Apple, Asus, etc. ne soutient pleinement le droit à la réparation. Ils ne sont d'aucune aide dans ce domaine. Ils se sont améliorés en fournissant des manuels pour le démontage de leurs ordinateurs et l'échange de pièces, mais pas pour une réparation au niveau de la carte. Toshiba doit être le pire. Cette société est absolument paranoïaque en ce qui concerne l'autoréparation. Elle est connue pour utiliser son armée d'avocats pour poursuivre les réparateurs. C'est une marque d'ordinateur portable qu'il vaut mieux éviter.
Il y a littéralement des centaines de vidéos YT sur les réparations qui peuvent probablement vous apprendre quelques trucs. Il existe également quelques cours en ligne (payants) qui enseignent les bases. Vous devez marcher avant de courir. Commencez par les bases. Il existe également de nombreuses possibilités d'apprentissage au sein de votre communauté. Ne sous-estimez jamais les cafés de réparation et les événements communautaires de réparation. Participez, observez et apprenez de ceux qui sont doués. Cela dépend bien sûr de l'endroit où vous vivez, etc.
J'espère que cela vous aidera un peu à naviguer dans les eaux troubles des schémas :-)
La réparation est la guerre contre l'entropie ! !
Indice 1
Pas facile.
Voir sur scribd
Sinon taper la recherche en plusieurs langues parfois on trouve.
Indice 0
1 commentaire:
Ok. Je vais essayer.
par
Souvent, les schémas de carte-mère sont confidentiels, leur partage est donc interdit. Il faudrait avoir de bonnes connaissances de recherche Google pour les trouver. Il faudrait par exemple taper sa recherche en anglais, inclure le type, le modèle ou le numéro d'identification du modèle de carte-mère par le fabricant, ajouter la mention "filetype:pdf" permet de n'afficher que des fichiers PDF sur Google.
Encore une fois, la majorité de ces fichiers étant confidentiels, vous ne devriez pas les télécharger, où alors à vos risques et périls.
Prenons l'exemple d'un Dell XPS 13 9370. Vous pourriez rechercher le "PCB Number" dans Google, et tomber sur un "motherboard model" noté LA-E671P. En reprenant ce numéro dans une nouvelle recherche, vous pourriez hypothétiquement tomber sur des liens vers des forums qui contiendraient le genre de résultats que vous recherchez.
Mais tout cela est hypothétique, et vous le savez déjà, partager ce genre de schémas est interdit...
Indice 0
Ajouter une réponse
PATSHOMWZ sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 13
30 derniers jours : 69
Total : 247
