Aller au contenu principal
Acer Aspire R7 Battery Replacement
Ce dont vous avez besoin
  1. Acer Aspire R7 Battery Replacement, Cover: étape 1, image 1 de 1
    • Shut down the laptop and disconnect the power cord.
    • Failing to disconnect or shut down the laptop could result in damage to the laptop or a shock hazard.
    • Turn the laptop over.
  2. Acer Aspire R7 Battery Replacement: étape 2, image 1 de 3 Acer Aspire R7 Battery Replacement: étape 2, image 2 de 3 Acer Aspire R7 Battery Replacement: étape 2, image 3 de 3
    • Remove seven 10 mm T7 screws.
    • Remove four 6 mm T7 screws.
    • Use the blue plastic opening tool to carefully remove both rubber pads which cover the four remaining screws.
    • Remove the remaining four 10 mm T7 screws.
  3. Acer Aspire R7 Battery Replacement: étape 3, image 1 de 1
    • Carefully lift the cover upwards.
    • If the cover seems stuck, use a spudger tool to pry the sides.
  4. Acer Aspire R7 Battery Replacement, Battery: étape 4, image 1 de 2 Acer Aspire R7 Battery Replacement, Battery: étape 4, image 2 de 2
    • Locate the battery ribbon connector
    • Remove the ribbon cable attaching the battery to the motherboard by carefully pulling it outwards
    • When using the spudger be careful around the motherboard as it can easily be damaged
  5. Acer Aspire R7 Battery Replacement: étape 5, image 1 de 3 Acer Aspire R7 Battery Replacement: étape 5, image 2 de 3 Acer Aspire R7 Battery Replacement: étape 5, image 3 de 3
    • Remove the three 4.5mm #00 Phillips screws attaching the battery to the motherboard
    • Push the 4 retaining clips away from the battery
    • Carefully lift the battery from the motherboard
12 autres ont terminé cette réparation.
F Fernandez
Membre depuis le 01/13/15
435 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 3-4, Hickman Winter 2015 Membre de l'équipe USF Tampa, Team 3-4, Hickman Winter 2015
USFT-HICKMAN-W15S3G4
4 membres
7 tutoriels rédigés
6 commentaires
great instructions
amaryheart7777777 - Réponse
What is the battery reference for replacement ?
skalpinou - Réponse
which battery model do I purchase for replacing on an Acer Aspire R?
Eddie - Réponse
hey how do you want då sel it for
Alex santos - Réponse
super tuto
Thanks
P.S : A have add a short comment on step 2.
Bests regards
Anthymoine - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 5
30 derniers jours : 27
Total : 41,211
