Aller au contenu principal
Acer Aspire R7 Battery Replacement
F Fernandez
F Fernandez et 8 autres contributeurs
Dernière mise à jour le February 14, 2025
10 minutes
Facile
Étudiant en action
Changing the Battery in an Acer Aspire R7 is a straightforward process if you find your computer has lost its ability to hold a charge.
The Aspire laptop battery enables the computer to work without having a power cord. It is a hardware component that is not externally accessible and requires a small amount of disassembly to replace.
The 4-cell replacement battery instructions are listed below in quick simple steps. Before using this guide make sure that the battery can no longer function in one of two ways, use a multimeter to test battery strength or check the settings on the laptop if possible.
If the battery is swollen be careful and proceed with caution and take appropriate precautions.
Ce dont vous avez besoin
Kit de réparation
Ce kit contient toutes les pièces et tous les outils nécessaires à la réalisation de ce tutoriel.
Pièces
Outils
Afficher plus…
  1. Acer Aspire R7 Battery Replacement, Cover: étape 1, image 1 de 1
    • Shut down the laptop and disconnect the power cord.
    • Failing to disconnect or shut down the laptop could result in damage to the laptop or a shock hazard.
    • Turn the laptop over.
    Use the blue plastic opening tool to carefully remove the rubber pad which covers the one remaining screw.
    Picture shows the rubber pad removed but srew to be removed is not indicated
    Anthymoine - Réponse
  2. Acer Aspire R7 Battery Replacement: étape 2, image 1 de 3 Acer Aspire R7 Battery Replacement: étape 2, image 2 de 3 Acer Aspire R7 Battery Replacement: étape 2, image 3 de 3
    • Remove six 6mm T7 screws.
    • Remove four 4mm T7 screws.
    • Remove two 10mm T7 screws
    • Use the blue plastic opening tool to carefully remove both rubber pads which cover the four remaining screws.
    • Remove the remaining two10mm T7 screws.
    Step 2 is missing the 1 (10mm T-7 ) screw that is under a rubber pad in the bottom middle of the laptop. The picture shows this pad and screw already missing. Note the silver color instead of the black color of the rest of the bottom of the laptop.
    Daniel Flynn - Réponse
  3. Acer Aspire R7 Battery Replacement: étape 3, image 1 de 1
    • Carefully lift the cover upwards.
    • If the cover seems stuck, use a spudger tool to pry the sides.
  4. Acer Aspire R7 Battery Replacement, Battery: étape 4, image 1 de 2 Acer Aspire R7 Battery Replacement, Battery: étape 4, image 2 de 2
    • Locate the battery ribbon connector
    • Remove the ribbon cable attaching the battery to the motherboard by carefully pulling it outwards
    • When using the spudger be careful around the motherboard as it can easily be damaged
  5. Acer Aspire R7 Battery Replacement: étape 5, image 1 de 3 Acer Aspire R7 Battery Replacement: étape 5, image 2 de 3 Acer Aspire R7 Battery Replacement: étape 5, image 3 de 3
    • Remove the three 4.5mm #00 Phillips screws attaching the battery to the motherboard
    • Push the 4 retaining clips away from the battery
    • Carefully lift the battery from the motherboard
12 autres ont terminé cette réparation.
F Fernandez
Membre depuis le 01/13/15
435 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 3-4, Hickman Winter 2015 Membre de l'équipe USF Tampa, Team 3-4, Hickman Winter 2015
USFT-HICKMAN-W15S3G4
4 membres
7 tutoriels rédigés
6 commentaires de tutoriel
great instructions
amaryheart7777777 - Réponse
What is the battery reference for replacement ?
skalpinou - Réponse
which battery model do I purchase for replacing on an Acer Aspire R?
Eddie - Réponse
hey how do you want då sel it for
Alex santos - Réponse
super tuto
Thanks
P.S : A have add a short comment on step 2.
Bests regards
thank you for your help.
paul cowley - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 22
Total : 41,600
