Aller au contenu principal
How to Fix a Brazilian Hammock
Ce dont vous avez besoin
  1. How to Fix a Brazilian Hammock, How to Fix a Brazilian Hammock: étape 1, image 1 de 1
    • Place the hammock on a flat surface.
    • Use scissors to cut the frayed ends from the damaged area.
  2. How to Fix a Brazilian Hammock: étape 2, image 1 de 2 How to Fix a Brazilian Hammock: étape 2, image 2 de 2
    • Align both sides of the tear leaving a quarter-inch gap between both sides of the tear.
    • Use safety pins to temporarily hold both sides of the tear together.
  3. How to Fix a Brazilian Hammock: étape 3, image 1 de 1
    • Cut a patch of the Ripstop fabric slightly larger than the tear.
  4. How to Fix a Brazilian Hammock: étape 4, image 1 de 1
    • Place the fabric on top of the tear and using safety pins temporarily hold the fabric to the hammock.
  5. How to Fix a Brazilian Hammock: étape 5, image 1 de 3 How to Fix a Brazilian Hammock: étape 5, image 2 de 3 How to Fix a Brazilian Hammock: étape 5, image 3 de 3
    • Be careful with the sewing needle. The end is very sharp.
    • Thread the needle and tie a knot at the end.
  6. How to Fix a Brazilian Hammock: étape 6, image 1 de 3 How to Fix a Brazilian Hammock: étape 6, image 2 de 3 How to Fix a Brazilian Hammock: étape 6, image 3 de 3
    • This step requires basic sewing skills but is easy to accomplish with time.
    • Use the threaded needle to sew from the bottom of the patch up and around the perimeter.
    • Make sure the needle and thread go through the patch and existing hammock material.
  7. How to Fix a Brazilian Hammock: étape 7, image 1 de 1
    • When finished tie a knot at the end of the stitch.
    • Make sure the knot is large enough, so it does not slip through the stitches.
  8. How to Fix a Brazilian Hammock: étape 8, image 1 de 2 How to Fix a Brazilian Hammock: étape 8, image 2 de 2
    • Remove all the safety pins and appreciate your work.
This guide is now completed, enjoy your newly restored hammock.
Desiree Galvan
Membre depuis le 08/29/23
157 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 41
Total : 99
