Aller au contenu principal
Repairing Nespresso Aeroccino Plus Motor
  1. Repairing Nespresso Aeroccino Plus Motor, Heat: étape 1, image 1 de 1
    • Heat up to 50°C/120°F in oven in order to make the clips inside smooth.
  2. Repairing Nespresso Aeroccino Plus Motor, Open: étape 2, image 1 de 2 Repairing Nespresso Aeroccino Plus Motor, Open: étape 2, image 2 de 2
    • Open the bottom with a strong screwdriver. Be careful not to break the clips inside
  3. Repairing Nespresso Aeroccino Plus Motor, Prepare: étape 3, image 1 de 2 Repairing Nespresso Aeroccino Plus Motor, Prepare: étape 3, image 2 de 2
    • Pull out the circuit board and the motor. After module is removed the on/off pad must be pressed in/through
  4. Repairing Nespresso Aeroccino Plus Motor, Swap Motor Contacts: étape 4, image 1 de 3 Repairing Nespresso Aeroccino Plus Motor, Swap Motor Contacts: étape 4, image 2 de 3 Repairing Nespresso Aeroccino Plus Motor, Swap Motor Contacts: étape 4, image 3 de 3
    • Check motor operation by pulling connector and applying 9V with an external power source (battery or bench supply) to the plug.
    • If the motor turns with reversed polarity then proceed by swapping black and red contacts leading to the motor. With a little flathead screwdriver press the contact spring, pull out the cable.
    • If the motor only turns by applying external power and a little twist or not at all, only solution is to replace the motor. Mabuchi RF-500TB-12560 is readily available on the internet.
  5. Repairing Nespresso Aeroccino Plus Motor, Close: étape 5, image 1 de 1
    • Carefully embed the thermal contact in conducting paste. Then press bottom into body until you hear a clic three times. At last switch must be pressed in.
To proof the function use water.
30 autres ont terminé cette réparation.
VauWeh
Membre depuis le 10/19/15
204 177 Réputation
246 tutoriels rédigés
Équipe
Repair is War on Entropy Membre de l'équipe Repair is War on Entropy
Community
25 membres
1 132 tutoriels rédigés
44 commentaires
Bravo, vielen Dank. Hat bestens funktioniert, in 5 min war alles erledigt!
jschiedermair - Réponse
Many thanks!
I couldn't believe reversing polarity would work, but it did!
J.
jeroenvaneijk - Réponse
Yes, it's a miracle. :-)
VauWeh -
If reversing the wires solves your problem then it was just a loose or poor contact at the switch causing the problem.
You are not switching polarity when swapping the wires. Like a light switch, it only serves as a connection/disconnection point for electrical flow.
ekao -
Gibt's da auch eine technische Begründung dazu, warum der bloße Tausch der Motoranschlüsse den Fehler behebt?
Ich würd's nur gerne verstehen.
Georg Sunkler - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 23
7 derniers jours : 230
30 derniers jours : 1,080
Total : 95,419
