Aller au contenu principal
Sorti en avril 2010 / Processeur Intel Core i5 2.4, 2.53 GHz ou Intel Core i7 2.66, 2.8 GHz
590 questions Voir tout
Can't select new SSD as startup disk
I installed a new SSD hard drive but Mac won't let me start up from it. Entire hard drive was restored on new prior to installation. I did a Mac recovery. All seemed okay until trying To reinstall mountain lion. Please help.
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
1 commentaire
Tell us how and on what the new drive was formatted.
par
Ajouter un commentaire
2 Réponses
Solution retenue
Go to About This Mac under the Apple menu then run System report (or System Profiler in older OS's). Then select Serial ATA and review the Partition Map Type of your SSD drive, it should be: GPT (GUID Partition Table). If not you will need to reformat it using Disk Utility app. and reinstall your OS and other files.
If it is the correct format type did you use the System Preferences Startup Disk and bless the SSD as the startup disk? If your system has two volumes with bootable OS's you must tell the system which one to use.
Indice 2
When you boot into the installer, did you select and partition the drive from Disk Utility?
You need to partition the drive and select a file system that Mac OS can use.
Indice 0
Ajouter une réponse
Mark Porro sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 14,435
