Aller au contenu principal
Acer Aspire E5-573G Battery Replacement
Ce dont vous avez besoin
  1. Acer Aspire E5-573G Battery Replacement, Optical Drive: étape 1, image 1 de 1
    • Ensure your device is OFF before beginning this procedure.
    • Unscrew the 5 mm Phillips head screw holding the drive in place.
  2. Acer Aspire E5-573G Battery Replacement: étape 2, image 1 de 1
    • Pull out the disk drive.
  3. Acer Aspire E5-573G Battery Replacement, Battery: étape 3, image 1 de 1
    • Unscrew the seventeen 5 mm Phillips head screws from the bottom cover.
  4. Acer Aspire E5-573G Battery Replacement: étape 4, image 1 de 1
    • Unscrew the three 2.5 mm Phillips head screws underneath the optical drive bay.
  5. Acer Aspire E5-573G Battery Replacement: étape 5, image 1 de 1
    • Run a pick between the bottom cover and the device around the edge of the laptop and unclip the cover from the rest of the device.
  6. Acer Aspire E5-573G Battery Replacement: étape 6, image 1 de 1
    • Lift the left side of the bottom cover, but do not completely remove the cover, as the speaker is cable is still connected and will be damaged.
    • Pull the speaker connector towards the fan to disconnect it from its socket on the motherboard.
  7. Acer Aspire E5-573G Battery Replacement: étape 7, image 1 de 1
    • Pull the battery connector towards the battery to disconnect it from its socket on the motherboard.
    • Remove the battery.
14 autres ont terminé cette réparation.
Alex Bahm
Membre depuis le 01/18/18
2 226 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team S12-G5, Banghart Winter 2018 Membre de l'équipe Cal Poly, Team S12-G5, Banghart Winter 2018
CPSU-BANGHART-W18S12G5
2 membres
15 tutoriels rédigés
Un commentaire
Where can i buy a battery replacement for my aspire e5-573g-59c3?
mfortich98 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 18
30 derniers jours : 73
Total : 21,642
