Aller au contenu principal
Beats Solo 3 Battery Replacement
Ce dont vous avez besoin
  1. Beats Solo 3 Battery Replacement, Battery: étape 1, image 1 de 2 Beats Solo 3 Battery Replacement, Battery: étape 1, image 2 de 2
    • Pry off the outside pane on the right side of the headphone with an opening tool.
  2. Beats Solo 3 Battery Replacement: étape 2, image 1 de 1
    • You should see your battery here. It will be square with yellow packaging.
    • Be sure not to pull on the wires that are connected to the outside panel. This may cause damage to your headphones.
  3. Beats Solo 3 Battery Replacement: étape 3, image 1 de 2 Beats Solo 3 Battery Replacement: étape 3, image 2 de 2
    • Grasp the battery's small bundled connector, and pull gently to remove.
    • Carefully remove the top attachment from the headphones with tweezers or your fingers.
  4. Beats Solo 3 Battery Replacement: étape 4, image 1 de 2 Beats Solo 3 Battery Replacement: étape 4, image 2 de 2
    • Use an opening tool or a nylon spudger to carefully remove the battery. Make sure you pry upward.
    • Do not bend or puncture the lithium-ion battery.
    • Once that is removed, make sure you peel off the sticker where the battery is placed if it stuck to the battery.
    • If it is, then place it back where it belongs in the headphones.
3 autres ont terminé cette réparation.
McKenzie Hosey
Membre depuis le 03/21/22
235 Réputation
1 tutoriel rédigé
Équipe
University of Alabama, Team 1-2, Bedsole Spring 2022 Membre de l'équipe University of Alabama, Team 1-2, Bedsole Spring 2022
UA-BEDSOLE-S22S1G2
4 membres
10 tutoriels rédigés
Un commentaire
Where too buy battery?
GSD - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 18
7 derniers jours : 155
30 derniers jours : 589
Total : 11,098
