Aller au contenu principal
Beats Studio 2 Wireless Bluetooth Board Replacement
Ce dont vous avez besoin
  1. Beats Studio 2 Wireless Bluetooth Board Replacement, Ear Cushion: étape 1, image 1 de 2 Beats Studio 2 Wireless Bluetooth Board Replacement, Ear Cushion: étape 1, image 2 de 2
    • Insert a spudger between the plastic part of the left headphone and the ear cushion.
    • Work the spudger around the periphery of the base of the cushion and gently pry it off the head phone.
  2. Beats Studio 2 Wireless Bluetooth Board Replacement: étape 2, image 1 de 3 Beats Studio 2 Wireless Bluetooth Board Replacement: étape 2, image 2 de 3 Beats Studio 2 Wireless Bluetooth Board Replacement: étape 2, image 3 de 3
    • Pull the rest of the cushion away from the adhesive with your hands.
  3. Beats Studio 2 Wireless Bluetooth Board Replacement, Speaker: étape 3, image 1 de 2 Beats Studio 2 Wireless Bluetooth Board Replacement, Speaker: étape 3, image 2 de 2
    • Using the Phillips #00 screwdriver, remove the screws holding the speaker in place.
    • If the speaker is on the side with the charging port be sure to keep the two screws holding the charging port separate.
  4. Beats Studio 2 Wireless Bluetooth Board Replacement: étape 4, image 1 de 1
    • Gently separate the speaker from the headphones.
    • Don't pull or yank the speaker from the headphones. They are connected together by wires that might be damaged.
  5. Beats Studio 2 Wireless Bluetooth Board Replacement: étape 5, image 1 de 2 Beats Studio 2 Wireless Bluetooth Board Replacement: étape 5, image 2 de 2
    • Gently pull the wire with rubber connectors off of the speaker.
  6. Beats Studio 2 Wireless Bluetooth Board Replacement: étape 6, image 1 de 1
    • Use a soldering iron to desolder the two connections.
    • For details on how to solder and desolder, refer to the How to Solder and Desolder Connections guide.
    • A soldering iron can produce very high temperatures, and can burn skin. Use with caution.
    • Note the position of the speaker in its housing, then carefully remove the faulty speaker.
  7. Beats Studio 2 Wireless Bluetooth Board Replacement, Bluetooth Board: étape 7, image 1 de 1
    • Peel off the sticker underneath the speaker.
  8. Beats Studio 2 Wireless Bluetooth Board Replacement: étape 8, image 1 de 1
    • Remove the center screw using a Phillips #00 screwdriver.
  9. Beats Studio 2 Wireless Bluetooth Board Replacement: étape 9, image 1 de 1
    • Separate the plastic case from the rubber backing by hand or with a spudger.
  10. Beats Studio 2 Wireless Bluetooth Board Replacement: étape 10, image 1 de 2 Beats Studio 2 Wireless Bluetooth Board Replacement: étape 10, image 2 de 2
    • Use a Phillips #00 to remove the four screws securing the case on top of the Bluetooth board.
  11. Beats Studio 2 Wireless Bluetooth Board Replacement: étape 11, image 1 de 1
    • Use a spudger to gently pry the left headband clip to free the earphone from the hinge.
    • This picture shows this for the right earphone, but the process should be exactly the same for the left side.
  12. Beats Studio 2 Wireless Bluetooth Board Replacement: étape 12, image 1 de 1
    • Slide the front case down to separate it from the back and reveal the Bluetooth board.
  13. Beats Studio 2 Wireless Bluetooth Board Replacement: étape 13, image 1 de 2 Beats Studio 2 Wireless Bluetooth Board Replacement: étape 13, image 2 de 2
    • Remove the four screws from the Bluetooth board with the Phillips #00 screwdriver.
    • This will free the Bluetooth board from the back case.
  14. Beats Studio 2 Wireless Bluetooth Board Replacement: étape 14, image 1 de 2 Beats Studio 2 Wireless Bluetooth Board Replacement: étape 14, image 2 de 2
    • Remove the Bluetooth board from the case.
    • Remove the translucent sticker from the back of the Bluetooth board.
  15. Beats Studio 2 Wireless Bluetooth Board Replacement: étape 15, image 1 de 1
    • Use the pointed tip of a spudger to carefully push on each side of the connector to remove it from the socket.
  16. Beats Studio 2 Wireless Bluetooth Board Replacement: étape 16, image 1 de 1
    • Desolder the RYB connectors, and the connector attached to the black wire using a soldering iron.
    • For information on desoldering connections, see the How to Solder and Desolder Connections Guide.
    • The soldering iron can reach very high temperatures. Use it with caution.
2 autres ont terminé cette réparation.
Jack Wilson
Membre depuis le 03/20/23
494 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 5-3, Ramos Spring 2023 Membre de l'équipe UMass Dartmouth, Team 5-3, Ramos Spring 2023
UMASSD-RAMOS-S23S5G3
3 membres
4 tutoriels rédigés
Un commentaire
Hi, can you help me out with a wiring diagram to the bluetooth board, all my wires got torn loose from my old board and i do not know where to solder the new wires to which connections. If you could post a picture with which coloured wires go where , that would be most helpful, thanks.
Roger Bee_44 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 17
30 derniers jours : 61
Total : 870
