Aller au contenu principal
Canon PowerShot SD1400 IS User Interface Panel Replacement
Ce dont vous avez besoin
  1. Canon PowerShot SD1400 IS User Interface Panel Replacement, User Interface Panel: étape 1, image 1 de 3 Canon PowerShot SD1400 IS User Interface Panel Replacement, User Interface Panel: étape 1, image 2 de 3 Canon PowerShot SD1400 IS User Interface Panel Replacement, User Interface Panel: étape 1, image 3 de 3
    • Remove the four 2.0 mm Phillips screws of the camera using the J00 bit from the 54-bit Driver Kit. There are two screws on both sides.
  2. Canon PowerShot SD1400 IS User Interface Panel Replacement: étape 2, image 1 de 1
    • Remove the 4.0 mm Phillips screw located on the bottom of the camera.
  3. Canon PowerShot SD1400 IS User Interface Panel Replacement: étape 3, image 1 de 1
    • Remove the front face panel of the camera by hand using firm pressure.
    • If one point of the face is stuck to the body, check if there is a screw preventing the front face from coming off.
  4. Canon PowerShot SD1400 IS User Interface Panel Replacement: étape 4, image 1 de 1
    • Remove the rear panel of the camera by hand using firm pressure.
  5. Canon PowerShot SD1400 IS User Interface Panel Replacement: étape 5, image 1 de 1
    • Remove the user interface panel by hand. The panel may fall out on its own, this is normal.
    • Replace the user interface panel by setting it in position.
2 autres ont terminé cette réparation.
Braxton Beal
Membre depuis le 01/30/18
696 Réputation
3 tutoriels rédigés
Équipe
Baylor, Team S1-G3, Johnson Spring 2018 Membre de l'équipe Baylor, Team S1-G3, Johnson Spring 2018
BU-JOHNSON-S18S1G3
3 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 8
Total : 248
