Aller au contenu principal
Dell Inspiron 13-5368 Battery Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 13-5368 Battery Replacement, Battery: étape 1, image 1 de 2 Dell Inspiron 13-5368 Battery Replacement, Battery: étape 1, image 2 de 2
    • Remove the nine 6mm Phillips #0 screws that secure the back cover of the laptop.
  2. Dell Inspiron 13-5368 Battery Replacement: étape 2, image 1 de 2 Dell Inspiron 13-5368 Battery Replacement: étape 2, image 2 de 2
    • Use a spudger to pry up and remove the back cover.
  3. Dell Inspiron 13-5368 Battery Replacement: étape 3, image 1 de 1
    • Remove the four 3mm Phillips #0 screws at the corners of the battery that secure it to the laptop.
  4. Dell Inspiron 13-5368 Battery Replacement: étape 4, image 1 de 1
    • Pull the battery cable's black tab towards the battery to disconnect it from the motherboard.
    • Pull the tab parallel to the motherboard, not straight up.
  5. Dell Inspiron 13-5368 Battery Replacement: étape 5, image 1 de 2 Dell Inspiron 13-5368 Battery Replacement: étape 5, image 2 de 2
    • Remove the battery.
For optimal performance, after completing this guide, calibrate your newly installed battery.
14 autres ont terminé cette réparation.
Matt Sugrim
Membre depuis le 09/27/17
1 042 Réputation
6 tutoriels rédigés
Équipe
USF Tampa, Team S14-G6, Boczar Fall 2017 Membre de l'équipe USF Tampa, Team S14-G6, Boczar Fall 2017
USFT-BOCZAR-F17S14G6
4 membres
13 tutoriels rédigés
3 commentaires
Awesome, very user friendly instructions. Was not looking forward to taking to computer repair store to replace internal battery. Thank you so much for these instructions.
rdcath - Réponse
The new battery replacement does not come with a cable to attach to the motherboard. How can I use the cable from the old battery?
BilboBaggins314 - Réponse
I have this same question^. Can I reuse the cable from the old battery?
Gloria Kolyabin -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 35
30 derniers jours : 198
Total : 24,388
