Aller au contenu principal
Dell Inspiron 13-7352 Battery Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 13-7352 Battery Replacement, Battery: étape 1, image 1 de 3 Dell Inspiron 13-7352 Battery Replacement, Battery: étape 1, image 2 de 3 Dell Inspiron 13-7352 Battery Replacement, Battery: étape 1, image 3 de 3
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Use a Phillips screwdriver to remove the ten 7.5mm screws that securing the back panel.
    • Use the plastic opening tool to pry up and loosen the back panel.
    • Remove the back panel.
  2. Dell Inspiron 13-7352 Battery Replacement: étape 2, image 1 de 2 Dell Inspiron 13-7352 Battery Replacement: étape 2, image 2 de 2
    • Use a Phillips screwdriver to remove the two 3 mm screws securing the battery.
    • Unclip the hard drive wire from the battery.
  3. Dell Inspiron 13-7352 Battery Replacement: étape 3, image 1 de 1
    • Gently remove the battery from the rest of the device.
For optimal performance, after completing this guide, calibrate your newly installed battery.
8 autres ont terminé cette réparation.
Mikinna Martin
Membre depuis le 09/25/15
458 Réputation
2 tutoriels rédigés
Équipe
University of Tampa, Team 1-5, Whiteside Fall 2015 Membre de l'équipe University of Tampa, Team 1-5, Whiteside Fall 2015
UT-WHITESIDE-F15S1G5
3 membres
6 tutoriels rédigés
3 commentaires
Last I looked up for a different model there was a video..
pc2053 - Réponse
Hello,
My Dell Inspiron 13-7352 won't turn on; I was using it when there was power outage and I totally drained the battery and it went off automatically, after the power came back I charged it the whole night but it still totally doesn't turn on. I tried to long-press the power button but nothing happens. I am 99% sure that the reason was using it on battery until the whole charge was gone. Please help!
jobgondwe - Réponse
My Dell did the same thing. I followed the above instructions to remove the battery and then put it right back in. Plugged into power and wa-la...it powered up. So simple. Thanks.
pcoladeb - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 11
30 derniers jours : 22
Total : 24,950
