Aller au contenu principal
Dell Inspiron 15 5577 Gaming Battery Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 15 5577 Gaming Battery Replacement, Battery: étape 1, image 1 de 1
    • Be sure to power off and unplug your device before you begin your repair.
    • Unscrew the back cover using a Phillips #0 screwdriver.
  2. Dell Inspiron 15 5577 Gaming Battery Replacement: étape 2, image 1 de 1
    • Remove the back cover using an opening tool.
  3. Dell Inspiron 15 5577 Gaming Battery Replacement: étape 3, image 1 de 2 Dell Inspiron 15 5577 Gaming Battery Replacement: étape 3, image 2 de 2
    • Use a T8 Torx driver to remove the five screws around the battery.
  4. Dell Inspiron 15 5577 Gaming Battery Replacement: étape 4, image 1 de 1
    • Remove the Battery Cable by gently tugging it perpendicular from the surface it is attached to.
  5. Dell Inspiron 15 5577 Gaming Battery Replacement: étape 5, image 1 de 1
    • Pull the battery out of the laptop by prying it away from the laptop. If you're having difficulty removing it, you can also use a plastic opening tool.
[deleted]
Membre depuis le 10/31/19
346 Réputation
2 tutoriels rédigés
Un commentaire
Thank you, you guys rock
Random User - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 11
30 derniers jours : 47
Total : 5,148
