Aller au contenu principal
Dell XPS 13 9310 Lower Case Replacement
Ce dont vous avez besoin
  1. Dell XPS 13 9310 Lower Case Replacement, Unfasten the lower case: étape 1, image 1 de 2 Dell XPS 13 9310 Lower Case Replacement, Unfasten the lower case: étape 1, image 2 de 2
    • Use a T5 Torx screwdriver to remove the eight 3.3 mm screws securing the case.
  2. Dell XPS 13 9310 Lower Case Replacement, Insert an opening pick: étape 2, image 1 de 2 Dell XPS 13 9310 Lower Case Replacement, Insert an opening pick: étape 2, image 2 de 2
    • Insert an opening pick between the lower case and the chassis on the front right edge.
  3. Dell XPS 13 9310 Lower Case Replacement, Release the case's front clips: étape 3, image 1 de 2 Dell XPS 13 9310 Lower Case Replacement, Release the case's front clips: étape 3, image 2 de 2
    • Slide the pick along the front edge to release the clips securing the lower case.
  4. Dell XPS 13 9310 Lower Case Replacement, Release the remaining clips: étape 4, image 1 de 3 Dell XPS 13 9310 Lower Case Replacement, Release the remaining clips: étape 4, image 2 de 3 Dell XPS 13 9310 Lower Case Replacement, Release the remaining clips: étape 4, image 3 de 3
    • Continue sliding the opening pick along the perimeter of the lower case to release the remaining clips.
  5. Dell XPS 13 9310 Lower Case Replacement: étape 5, image 1 de 3 Dell XPS 13 9310 Lower Case Replacement: étape 5, image 2 de 3 Dell XPS 13 9310 Lower Case Replacement: étape 5, image 3 de 3
    • Lift the lower case from the chassis and remove it.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
Take your e-waste to an R2 or e-stewards certified recycler.
Repair didn't go as planned? Try some basic troubleshooting, or ask our Dell XPS answers community for help.
2 autres ont terminé cette réparation.
Spencer Day
Membre depuis le 09/14/22
55 209 Réputation
408 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
136 membres
17 439 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 6
7 derniers jours : 30
30 derniers jours : 90
Total : 1,323
