Introduction
In order to gain access to most of the internal components the top (or lid) of the printer must be removed. This guide is intended as a prerequisite for other installations.
Pièces
Aucune pièce nécessaire.
Open the front access panel by placing your finger in the front slot and pulling gently.
  • Open the front access panel by placing your finger in the front slot and pulling gently.
Ajouter un commentaire
Open the protective lid that is covering the glass. Press gently against the base of the panel to remove the lid from the rest of the printer.
  • Open the protective lid that is covering the glass. Press gently against the base of the panel to remove the lid from the rest of the printer.
Remove the four 9mm T10 Torx screws on the top. Remove the four 9mm T10 Torx screws on the top. Remove the four 9mm T10 Torx screws on the top.
  • Remove the four 9mm T10 Torx screws on the top.
Carefully lift the top panel off of the printer. Do not tear or damage the two cables that connect the top lid to the motherboard.
  • Carefully lift the top panel off of the printer.
  • Do not tear or damage the two cables that connect the top lid to the motherboard.
Remove the two cables by gripping each one close to their connection ports on the motherboard and gently disconnecting them. Remove the two cables by gripping each one close to their connection ports on the motherboard and gently disconnecting them. Remove the two cables by gripping each one close to their connection ports on the motherboard and gently disconnecting them.
  • Remove the two cables by gripping each one close to their connection ports on the motherboard and gently disconnecting them.
16 autre(s) ont terminé cette réparation.
Tim
Membre depuis le 15/01/2013
131 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 18-35, Regan Winter 2013 Membre de l'équipe Cal Poly, Team 18-35, Regan Winter 2013
CPSU-REGAN-W13S18G35
5 membres
8 tutoriels rédigés
I want fix my HP DESKJET F448o, My problem is, that the scanner arm is block.
When I turn on, the scanner arm is block, how can fix its?
mbeto0351 - Réponse
Voir les statistiques:
Dernières 24 heures : 4
7 derniers jours : 21
30 derniers jours : 99
Total : 5,811
