Aller au contenu principal
Garmin Nuvi 200 Battery Replacement
Ce dont vous avez besoin
  1. Garmin Nuvi 200 Battery Replacement, Rear Casing: étape 1, image 1 de 2 Garmin Nuvi 200 Battery Replacement, Rear Casing: étape 1, image 2 de 2
    • Peel off the sticker from the bottom of the device to reveal two screws.
  2. Garmin Nuvi 200 Battery Replacement: étape 2, image 1 de 1
    • Remove two T5 Torx screws.
  3. Garmin Nuvi 200 Battery Replacement: étape 3, image 1 de 2 Garmin Nuvi 200 Battery Replacement: étape 3, image 2 de 2
    • Insert a plastic opening tool in the gap between the front and rear casing.
    • Carefully work the tool around the gap, separating the two halves of the case.
    • Keep the power switch in place while removing the rear case.
  4. Garmin Nuvi 200 Battery Replacement, Logic Board: étape 4, image 1 de 1
    • Peel away the tape holding the ribbon cable in place.
    • Disconnect the ribbon cable by using a spudger to flip up the retaining flap on its ZIF-style connector. Then gently remove the cable.
  5. Garmin Nuvi 200 Battery Replacement: étape 5, image 1 de 1
    • Pull out the cable between the logic board and the speaker to disconnect them.
  6. Garmin Nuvi 200 Battery Replacement: étape 6, image 1 de 2 Garmin Nuvi 200 Battery Replacement: étape 6, image 2 de 2
    • Remove the three screws from the logic board using the #00 Phillips screwdriver.
    • Lift the board away from the case but do not pull the logic board completely off, as it is still attached to the battery by a cable.
  7. Garmin Nuvi 200 Battery Replacement: étape 7, image 1 de 2 Garmin Nuvi 200 Battery Replacement: étape 7, image 2 de 2
    • Detach the logic board form the battery by pulling out the cable.
  8. Garmin Nuvi 200 Battery Replacement, Battery: étape 8, image 1 de 2 Garmin Nuvi 200 Battery Replacement, Battery: étape 8, image 2 de 2
    • Do not use any sharp objects around the battery, as these may puncture the battery.
    • Remove the battery by pulling it away from the casing.
    • The battery is glued to the casing.
18 autres ont terminé cette réparation.
Anjelica
Membre depuis le 04/11/10
564 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 25-90, Amido Spring 2010 Membre de l'équipe Cal Poly, Team 25-90, Amido Spring 2010
CPSU-AMIDO-S10S25G90
4 membres
9 tutoriels rédigés
13 commentaires
This document could be improved by including information about where to acquire a replacement battery, and any modifications that might be required to a generic battery.
Jonathan Moore - Réponse
Seems like there are some on Amazon and Ebay. Not sure how to verify getting the right one. Not that expensive, so maybe worth the risk.
Jim Carnicom - Réponse
It was a huge mistake to peel away the ribbon cable. It needs matched up precisely and exactly in the same alignment as it was before during reassembly, an apparently impossible task once it's been detached. I'd advise opening the halves in book form, leaving the ribbon cable as a hinge. Have about given up trying to position it.
Nice tutorial, except for the booby trap.
gepetto4 - Réponse
Yep, fell into this trap, too. The Nuvi powers up but no video. Can't place the ribbon cabe just exactly so. Ugh.
webo666.666 -
Cannot stress enough that the step 5 calling for the removal of the tape holding the ribbon cable be removed from this guide! My Nuvi will not work anymore because I can't get that ribbon cable aligned. I wish I had read all the comments as the above poster warned of this very problem. Please update the guide and remove step 5!
Jarrod - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 24
30 derniers jours : 89
Total : 48,092
