Introduction
You will use the fan repair guide to get to the CPU. Then, you will use the lock to remove the CPU.
Pièces
Aucune pièce nécessaire.
Place the laptop so the back cover is facing up.
  • Place the laptop so the back cover is facing up.
Ajouter un commentaire
Remove the 8 screws from the back cover using the Phillips #00 screwdriver.
  • Remove the 8 screws from the back cover using the Phillips #00 screwdriver.
Lift off the cover.
  • Lift off the cover.
Unplug the fan’s power cable, which is a group of black wires attached to a white plastic head on the motherboard.
  • Unplug the fan’s power cable, which is a group of black wires attached to a white plastic head on the motherboard.
  • Pull the plastic part of the cable, not the wires, so that the plug does not break.
Remove the two screws located on opposite sides of the fan with a Phillips #00 screw driver.
  • Remove the two screws located on opposite sides of the fan with a Phillips #00 screw driver.
The fan is permanently attached to the silver heat sink next to the RAM.
  • The fan is permanently attached to the silver heat sink next to the RAM.
  • To completely remove the parts, loosen the heat sink’s four screws with a Phillips #00 screw driver.
  • Take out the screws in the numerical order shown on the heat sink.
Pull the fan and heat sink toward you at a 20 degree angle upward.
  • Pull the fan and heat sink toward you at a 20 degree angle upward.
The CPU is located under the heat sink you just removed. It is a green card on a white plastic surface. There is a black lock on one side of the plastic. Rotate the CPU lock 180 degrees counterclockwise with a 3.0 mm Flathead screw driver.
  • The CPU is located under the heat sink you just removed. It is a green card on a white plastic surface. There is a black lock on one side of the plastic. Rotate the CPU lock 180 degrees counterclockwise with a 3.0 mm Flathead screw driver.
  • You will hear a click as the lock unlocks.
Place your fingers on opposite edges of the green card.
  • Place your fingers on opposite edges of the green card.
  • Carefully lift the CPU upward.
Toni Pipes
Membre depuis le 05/10/2010
297 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 21-31, Regan Fall 2010 Membre de l'équipe Cal Poly, Team 21-31, Regan Fall 2010
CPSU-REGAN-F10S21G31
4 membres
7 tutoriels rédigés
Memory address registers and memory data registers together can represent the gateway?if can how?
Jayita Roy - Réponse
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 4
Total : 6,645
